Alignment
Old Feb 10, 2010 | 05:38 PM
64F260's Avatar
64F260
I don't mean to hijack this thread, but my 2000 4x4 F250 with brand new tires (265's) also wanders. Had it aligned, and no improvement. The truck has what appears to be new ball joints and some new tie-rods. The alignment guy said to give it some time, new ball joints will cause it till they are worn in a little. Sounds a little fishy, but he has a good rep, and has been doing alignments for years. I am a little skeptical though. Waiting to see where this thread goes...
Old Feb 10, 2010 | 05:47 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Wandering can be the result of not enough positive caster or negative toe (toe out).
I have been adjusting the steering sector shaft freeplay on every Super Duty that comes in here because they ALWAYS "wander" because of excessive backlash that results in a lot of steering wheel input to make the truck "move".
Many times I actually end up with 1-1.5 turns of the adjustment screw just to take up the lash.
Old Feb 10, 2010 | 06:12 PM
mxfam4x4's Avatar
mxfam4x4
Here is how it ended up Cody,
left frt
0.6 camber
3.4 caster
0.08 toe
right frt
0.4 caster
4.2 camber
0.01 toe
cross camber 0.2
cross caster -0.8
total toe 0.08
I know it's not to your recomendations exactly but It doesn't drift to the right now and the wandering is alot better, I guess I will have to waite and see how they wear now. There is always someone with a shoulder to whine on here with years of experience to assist us down the path.
Thanks again for the advise folks!!
Old Feb 10, 2010 | 06:37 PM
Bowie's Avatar
Bowie
Not sure what the lower ball joints are but I had a guy look at the truck before I bought it. He lifted the truck off the ground and used a big pry bar on the wheel and somewhere else on the axel and he said it was fine. I am assuming those where the ball joints. I do have a pitman arm grease boot that is ripped.
How far do you know to turn the stering box screw. I have heard that if you do it to far that it can screw it up.
Old Feb 10, 2010 | 06:48 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes, you can turn it too far. I only adjust it until the steering wheel takes about 1/2" from either side of center to make a toe change on the machine.
If you go too far, the steering will bind while turning and affect the automatic "return-to-center" action you get after making a turn. It can also wear the sector shaft bushings excessively if the lash is taken up too much and a bind is created.
Old Feb 10, 2010 | 07:12 PM
Bowie's Avatar
Bowie
So sounds like something the average person should not screw with?
Old Feb 10, 2010 | 08:39 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I certainly wouldn't say that I'm "above average".
I can say with absolute certainty that if you have a truck with the stock steering box and at least 80,000 miles, you should be able to turn the screw 1/2 to 3/4 turn.
Old Feb 11, 2010 | 05:53 PM
MiamiPSD's Avatar
MiamiPSD
Cody,
I have a 03 7.3L PSD 4X2 with the standard 265x75x16 tires. Where should I have my caster/camber, toe setting at? thxs
Old Feb 11, 2010 | 07:28 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Specs for camber are -0.75 to +1.25 "perfect" is +0.25
Specs for caster are +1.5 to +5.5 "perfect" is +3.5
Specs for toe are -0.220 to +0.280 "perfect" is +.03
Have the camber put at +.5
Left caster at +3.5, right caster at +4.0
Toe at +.07 to 1.0
Old Feb 11, 2010 | 07:56 PM
MiamiPSD's Avatar
MiamiPSD
Thank You.........................................
Old Feb 12, 2010 | 09:06 AM
tbone heller's Avatar
tbone heller
When adjusting for "road crown", one must remember that the roads in the south have very little road crown & the left & right camber & caster measurements on these southern vehicles usually mirror themselves. Trucks aligned with northern road crown style alignments tend to lead to the left when driven on southern roads. An experienced alignment shop in your area should know what is needed for your road conditions.
davalt75
Sep 30, 2014 08:56 PM
turnkyle
20
Sep 1, 2014 08:28 PM
IslandBlueV10
Sep 17, 2013 11:11 PM
AggieFord
6.7L Power Stroke Diesel
Jul 1, 2013 05:31 PM
flat4vw
Oct 14, 2004 01:56 PM
