Another ?
Old Feb 2, 2010 | 09:28 PM
charles09's Avatar
charles09
Talking Another ?
My Right Driver Side Tire is starting to wear from the middle of the tire to the outside. also my truck wants to veer to the right when i let go of the steering wheel it veers hard to the right?
Is this a stuck brake? Alignment Issue? or what?
I know I'm
Old Feb 2, 2010 | 09:37 PM
starmilt's Avatar
starmilt
Alignment a stuck brake that wears out a tire is a flatspot all the way across the tire.
Old Feb 2, 2010 | 09:38 PM
charles09's Avatar
charles09
oh okay. I'm gonna wear it down till i see wires and change all 4. also I got another question for you? When my truck starts up in the morning I have some blue smoke and white to sometimes is this something to worry about? is it bad??
Old Feb 2, 2010 | 09:41 PM
rupejosh's Avatar
rupejosh
i would say you need an alignment badly.as far as the smoke at start up thats pretty normal
Old Feb 2, 2010 | 09:45 PM
charles09's Avatar
charles09
okay I was just making sure lol I didnt wanna think my dang truck was blowed up I do however have leaking valve cover gaskets on both sides of the motor i need to replace I can smell the oil fall down on the manifold
Old Feb 3, 2010 | 03:21 AM
Rick Wallace's Avatar
Rick Wallace
I live on the same road as the fire cheif in my area, he says 7 out of 10 vehicle FIRES are caused from leaking oil onto hot exhaust,so please fix that ASAP!
Old Feb 3, 2010 | 03:30 AM
hairyboxnoogle's Avatar
hairyboxnoogle
As far as the tire wearing in the middle, that sounds like over inflation, and / or tire seperation. Blue smoke would indicate that its burning oil, likely that the rings are worn and letting some oil stay on the cylinder walls, or possibly a leaky valve seal letting oil drip into the cylinder. Grey to white smoke is normal... bright white smoke is bad, means the engine is trying to burn water due to a crack in the head or block or a faulty head gasket.
Old Feb 3, 2010 | 06:03 AM
charles09's Avatar
charles09
I'm talking about a cold start!!
Old Feb 3, 2010 | 08:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Cold start white smoke is from unburnt fuel from lack of heat in the engine block.
It should clear as soon as the engine starts warming up.
Middle to outside on the drivers side, are you taking some right hand turns really fast?
Most likely your issue is alignment.
Hit any curbs hard or huge potholes with the drivers side tire?
Also could be worn steering parts.
Old Feb 3, 2010 | 08:35 PM
charles09's Avatar
charles09
no. if i let go of the steer wheel while driving it veers to the right very hard. thats how come for me wearing my tire out obviously I'm not sure.
