Steering box adjustment
Old Jul 30, 1999 | 08:10 PM
Dan Blackwell
Guest
Posts: n/a
What's the procedure for taking up some slop in the steering gear box on my '68 F100 (360, 3-spd, armstrong). All the other connection points in the steering are real tight. Thanks in advance. DB
Old Jul 30, 1999 | 09:28 PM
Pup's Avatar
Pup
If you have power steering there should be a screw with a nut to lock it in place on top of the steering box. If it is manuel steering it may also be on top of the box, but it might be on the side of the box.
Old Aug 1, 1999 | 01:11 PM
Ozzie's Avatar
Ozzie
Here's something I did that worked. I loosened up the adjusting nut on top of the gear box. Then I jacked up the front of the truck enough to get the front tires off the ground. I loosened the nut up all the way and then got in the truck and turned the wheel from stop to stop a good couple of times. Then I set the wheels straight and tightened the nut down to where it felt right. Of course, lower the vehicle back down and adjust as necessary. It didn't take all the slop out, but it helped tighten the majority of it out. Hope that helps. Of course, if it's real bad, larescorp.com is a good site to get a reman gear box for a reasonable price. Ozzie
70 F-100 Stepside
302 V-8, 3spd
Old Aug 1, 1999 | 02:15 PM
jowilker's Avatar
jowilker
zombiefied 247
Oct 30, 2012 04:58 PM
ron9
Sep 29, 2007 07:04 PM
oldhalftons
Aug 3, 2004 08:43 PM
bjoern
Aug 9, 2001 01:20 AM
dinosaurfan
Jun 1, 2001 06:43 PM
