Yep spacers will work. Like AH said its if you want to use them or not. I think if you buy spacers that are quality made and aren't a crazy width then it's not much different then DRW trucks using them. Problem is by the time you buy the spacers and the wheels it's almost as cheap to buy wheels with the proper backspacing in the first place. That is unless you get a real good deal on the wheels.
