I have a 78 F-150 the window seals have gone and when your on the highway they whistle alot. I went to the ford dealer here and they wanted $350 A side!. does any one know how I could fix this problem, or where I could get some window seals cheaper?.
Joe,
You can get 'em cheaper just about anywhere. Dennis Carpenter, Autokrafters even JC Whitney. I guarantee you can redo both doors, gaskets, vent window seals scrapers and runs for less then the dealer wants for the one seal.
I've replaced all of the window seals on my 65
f100 for about $160.00 from Obsolete Ford Parts
in Oklahoma City, This kit is just like original
equipment. 1-405-631-3933
You can go to a local junk yard and get the window chanel seals out of a newer truck and install them. The inner and outer seals are still available through ford for about 20.00 each, these seals are the ones that fit on the outer door shell and the inner door shell. But the one making the noise is the chanel seal.
>seals cheaper?.
>Thanks alot,
> Joe
Just to add to the list>>
I replaced the `Rear Slider` window seal, 72` f-250 for $39.00 american. with shipping and Tax $46.00
Might try "Weather Strip Special" San Jose, Calif 95116 1-888-999-7876 E-Mail>> info@weatherstripspecial.com
Gm, Ford, Chrysler,and AMC
I found some herein london ontario called NOS REPRODUCTIONS they have everything in stock and will ship I just ordered a set for my 79 f-100 $138.00 per door here's the number 1-800-677-6200 or 1-519-471-2740 good luck....Dave
Ozzy1, welcome to the best forum around.
Congratulation for chosing the best Ford Truck Enthusiasts as your ultimate resource center for information.
You have created the oldest and longest running thread in the FTE forum (1999-2006).
