Need Advice
Old Feb 2, 2010 | 06:55 AM
cworley250sd's Avatar
cworley250sd
Need Advice
I am looking at buying another truck, I found a 2001 F250 7.3L for sale and the price is where I need it to be. The only issue I have found so far is the truck has 320000 miles. I have never owned a diesel my self I do work on them here at work (oil changes, glow plugs, etc.) and some of them have high mileage and seem to run fine. Should I walk away from this truck, or should I buy it, what should I look for under the hood? I am going at lunch to look/possibly buy it so any help would help me make an informed decision. I did ask why the high miles and was told they have oil leases in Midland, TX and Brecken Ridge and drove between them constantly.
Old Feb 2, 2010 | 07:17 AM
Kwikkordead's Avatar
Kwikkordead
That's a lot of miles.
That doesn't mean it's a bad thing, but you need to check the general health of everything.
The engine might still run good, but how about the wheel bearings?
What are your plans for the truck?
Transmission?
Driveline?
Do all the accessories work?
Do all the windows roll up and down?
Body rust?
Brakes?
Ball joints?
Spring shackles?
Old Feb 2, 2010 | 07:18 AM
riverrat41's Avatar
riverrat41
Check it out good.Those ranches out there are plenty rough driving from well to well if thats what it was used for.Check the ball joints,knuckles,put it in 4x4 and turn it side to side.Listen for pops and unusual noises.Engine wise,remove the intake and look to see what shape the turbo wheel is in.If it is dusted you might want to keep looking.Yes,the turbo can be fixed but think about what got sucked into the motor....Good luck
Old Feb 2, 2010 | 07:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
That is a lot of miles. Get ready to spend some money of things that will be going out. Not saying things will go out, but if you don't have a maintenance record on this truck, look very close. Good luck.
Old Feb 2, 2010 | 07:56 AM
cworley250sd
Thanks for the replies, I will be using this truck to replace my 2000 F250 5.4. Basically daily driver, back and forth to work, and pulling 28' fifth wheel ocassionaly on the weekends.
Old Feb 2, 2010 | 08:02 AM
Kwikkordead
If it's going to be a daily driver, keep the 5.4 for a while as a backup until you are certain that the PSD is going to hold up.
320,000 is a lot of miles and by this time, anything could be wrong.
One thing, when you hook up that trailer and start out, you'll be floored at how much better that diesel tows compared to that little 5.4.
Old Feb 2, 2010 | 08:35 AM
robs01f250's Avatar
robs01f250
Where are you located?? Maybe someone could meet up with you that has a scanner (AE) that could run a couple of tests on the truck to see how the health of the truce is
Old Feb 2, 2010 | 08:39 AM
miller_feed
He lives in Texas according to his profile.
Old Feb 2, 2010 | 08:59 AM
cworley250sd
I really don't know what to do, I need to get another truck as my 5.4l it dying a slow death, but I don't want a money pit, I am trying to decide between the 2001 7.3 4x4 SC LB 320000miles for around $5000 or a 2003 v10 SC LB 4x4 240000miles for around $4000 what do you guys think?
Old Feb 2, 2010 | 09:13 AM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
cworley250sd,
If you are going to be towing a 5th wheeler. It is not cheep to pay a tow bill for a truck and a camper. I would suggest you need to purchase a good road service plan. I have Good Sams, they will pay towing on truck and camper.
Old Feb 2, 2010 | 12:08 PM
madjak's Avatar
madjak
I would keep looking around. Both of those trucks have a lot of miles and probably will need some things repaired right away. I would spend a little more and try and get something with less miles. Unless you can get the service records for a high mileage truck, I would keep looking for something 100k-150k miles. How many miles on your 5.4?
Good luck,
Old Feb 2, 2010 | 12:11 PM
just another truck's Avatar
just another truck
Ford F-350 Crew Cab
Call me when you need to be picked up from the airport??
Ford_Six
Aug 8, 2014 09:09 PM
reamer
Apr 27, 2013 07:12 PM
Franko72
39
Mar 24, 2013 10:44 AM
midland_dave
Jun 9, 2011 10:21 AM
CWaters75
40
Jan 11, 2004 07:08 PM
