Wont Start??
Old Feb 4, 2010 | 12:11 PM
  #31
WarOzz's Avatar
WarOzz
Congrats! so it was the pump?
Old Feb 4, 2010 | 01:19 PM
  #32
HORSINROUND's Avatar
HORSINROUND
The pump was lookin pretty beat so i swapped it anyways it was puttin out fuel but figured why not? i had already bought the thing anyways rather do it in shop than on side of road. I think it was mostly at that stupid tank valve though
Old Feb 4, 2010 | 06:03 PM
  #33
WarOzz's Avatar
WarOzz
Ah I see, well keep us posted! It's nice to hear when a guy solves a problem, just makes it easier on the rest of us when we have the same problems pop up.
Old Feb 5, 2010 | 01:44 PM
  #34
HORSINROUND
DAMN IT!! I am dang near ready to sell this pos truck and go by a cummins. i took it up the road to look at elk last night and the freakin thing died again! Then i had to get pulled home by my father in laws chevy c'mon anything but a chevy! I dunno what the heck to do now, this thing leaks oil like crazy, has worse mood swings than my wife and doesnt want to run when i actually need the frickin thing!! Anyone want a 90 idi for cheap let me know.
Old Feb 5, 2010 | 02:06 PM
  #35
FORDF250HDXLT's Avatar
FORDF250HDXLT
so your fuel gauge doesn't work on either tank?
define "messed around with FSV (fuel selector valve)" ?
how much fuel is in each tank?
have you tested for voltage at the FSV?
you can bypass the FSV pretty easy.Just hook the front tank up directly and see if it runs fine.if not,you may have a bad pickup in that tank.hook up the rear tank and try it again.
if it runs fine hooked directly to both tanks(one at a time of course) then you found your problem= bad FSV.either replace it,or just use one tank.
Old Feb 5, 2010 | 02:09 PM
  #36
Rick Wallace's Avatar
Rick Wallace
I can relate to this young man!!!!!!!!
Old Feb 5, 2010 | 02:13 PM
  #37
HORSINROUND
plannin on doin it when i get home, gonna put a flatbed on it anyways so im taking bed off, ill do it then; i blew air through the lines and through the valve just to blow all the crap out of it i thought i sucked out of the tank
Old Feb 5, 2010 | 02:20 PM
  #38
FORDF250HDXLT
ahh.the FSV is very low pressure rated.it can't handle more than a few psi.you may have blown it by blowing in it.
if you get a new one.don't do that again.don't want to ruin a new one just so ya know.
Old Feb 5, 2010 | 02:35 PM
  #39
HORSINROUND
ah crap, should of knew that i guess, would it be a bad idea to just use one bigger tank? less things to go wrong
Old Feb 5, 2010 | 02:49 PM
  #40
FORDF250HDXLT
yeah sure.you can.as long as you can find a place for it under there,and comes with a pick up.needs a feed/return line/and vent.
stay away from one with an in tank high pressure electric pump,or you would need a regulator/block off plate for stock lift pump/high pressure rated fuel line/new electric lines to feed it etc.
if you bypass it to test,and see its faulty.its pretty simple and low cost to just replace it.for more info see here:
https://www.ford-trucks.com/forums/9...el-gauges.html
but test for voltage and bypass it first before just replacing it,as it may not be your problem of course.
Old Feb 5, 2010 | 02:57 PM
  #41
HORSINROUND
i have a fuel cell i was going to put on my flatbed, would there be any problems just running fuel from it to the lifter pump?
Old Feb 5, 2010 | 03:21 PM
  #42
FORDF250HDXLT
hmm i dunno.im sure some guys have done it.i wouldn't think the tank up on a bed would be any problem.i would think the lift pump could handle that without issue.
you need a return line to it of course,as the fuel is used to cool the injectors/ip pump in our systems.
if pumping this high on the return would be an issue(again,i really doubt it),im sure someone will chime in.
Old Feb 5, 2010 | 03:26 PM
  #43
macman85602's Avatar
macman85602
A tank form a bronco may work to replace the rear tank. i believe they are a 33 Gal tank but could be wrong. you would need to move the spare tire though
Old Feb 5, 2010 | 04:00 PM
  #44
HORSINROUND
i might just only use the front tank to save the work and bed space
Old Feb 13, 2010 | 03:30 PM
  #45
6x6custom77's Avatar
6x6custom77
take a rag soak it with gas and put it over the intake filter( gas works even better than either), if you can get it to fire its a fuel pump( probally a mechanical fuel pump depending on your year), injector problem, or CPS crank position sensor, if the computer dosen't read this it will not deliver fuel plus they are notorious for going out from what i'll seen
