Wont Start??
Old Feb 2, 2010 | 11:38 AM
HORSINROUND's Avatar
HORSINROUND
id hurt myself tryin to run a hairdryer anyways
Old Feb 2, 2010 | 12:01 PM
WarOzz's Avatar
WarOzz
Some things you just don't tell your friends either lol. Plug in and turn it on... Think of it as a heat gun not a hair dryer.
Old Feb 2, 2010 | 01:20 PM
84 f250 6.9's Avatar
84 f250 6.9
[ Think of it as a heat gun not a hair dryer.[/quote] heat guns work even better .. but be careful i had a small engine fire doing that cuz i caught my air filter on fire
Old Feb 2, 2010 | 01:44 PM
Links56's Avatar
Links56
I would make sure that the IP has power to it first. That stupid fusible link could go out at any time. See if there is fuel in the filter.
Old Feb 2, 2010 | 04:58 PM
HORSINROUND
Im kinda leanin towards the fuel tank switch valve, it was runnin like a raped ape till i switched tanks
Old Feb 2, 2010 | 08:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If you turn the key on, engine off, switch tanks.
Can you hear the selector valve run?
Does the fuel gauge change to indicate the fuel level in each tank?
Old Feb 2, 2010 | 10:29 PM
macman85602's Avatar
macman85602
Which tank were you on when you switched.
i was running on what i thought was the front tank switched to the rear and nothing. I came to find out the switch had defaulted to the rear and the front was still full. It was a bad switch valve.
Old Feb 3, 2010 | 09:50 AM
HORSINROUND
I can hear the switch when i change tanks, and i was on the front tank then changed to the rear one, there should of still been fuel in the front one though i didn't want to run it empty, i thought that was like an unwritten law on diesels? If i do have plenty of fuel and there isn't any air leaks why wouldn't it run? It was running great then just quit in a day
Old Feb 3, 2010 | 10:09 AM
starmilt's Avatar
starmilt
Vents can stop up making it pull a vacumn, is a possibility bit I would think after it sat overnight the vacumn would be gone. A restriction in the line somewhaer possibly the selector valve. Fuel pump it self could have gone bad have you run a pressupe and volume test. Ip itself could have gone bad. lots of possibilities. A pressure and volumn test will eliminate most of them and show you where to start looking.
Old Feb 3, 2010 | 10:15 AM
HORSINROUND
Okay i will get them done as soon as i get home and post results, thanks again for the help
Old Feb 3, 2010 | 11:54 AM
macman85602
How are the pickup tubes in the tanks. if there is a combination of a broken pickup tube and a bad valve (mine still clicked but didn't work) that would cause your problem
Old Feb 3, 2010 | 12:08 PM
nappy nate's Avatar
nappy nate
did you look for ice in your fuel filter like star brought up , it happens and it will stop you cold if you have water in the bottom of the filter and its super cold it will form a ice cube and stop the flow of fuel.
nate
Old Feb 3, 2010 | 12:18 PM
  #28
HORSINROUND
Im putting a flatbed on it asap so when i do im goin to replace them and get the freakin fuel guage workin finally, i swapped the filter not even a month ago and the other day when i was checking fuel i have the same coming out of the filter as i do goin into it, i gotta do the 1/3 pint and pressure test to see if im getting enough fuel but i really think it is the tank selector valve or something back in that area, it was runnin great till i changed tanks, but i wanna make sure i didnt ruin the lifter pump or the IP while im workin on it
Old Feb 3, 2010 | 09:06 PM
  #29
Dave Sponaugle
What year is the 6.9 that is in there?
Old Feb 4, 2010 | 12:06 PM
  #30
HORSINROUND
SHE LIVES!! Its out of an 87, had 78k on it when i swapped them, i got the truck in my shop last night and changed o-rings, lifter pump and messed around with the tank selector valve for a minute then bled the lines changed filter and she fired right up, sounds like its runnin about the same as it did before so yeah hopefully fixed it better than before
