Clutch chatter
Old Aug 3, 1999 | 06:30 PM
Dan Blackwell
Guest
Posts: n/a
Clutch chatter
I posted a while back about a new clutch in my '68 360 F-100 that caused a bad vibration. Well, the mechanic got rid of that clutch and put and put in one that had just as bad a chatter/grab at take off. The one after that had the same problem just to a lesser degree. Anyway, he's going back into it tomorrow for the fourth time. All that hasn't been done is to replace the pilot bearing. A new (not reman) pressure plate, disk and release bearing have all been installed more than once. Anybody know the trick to making this thing work right? DB
Old Aug 4, 1999 | 08:12 AM
ray's Avatar
ray
Clutch chatter
Nowhere did I see that you had the flywheel resurfaced. Have it done and check for runout. Can't believe this won't "fix" the chatter. Good luck,
ray
Old Aug 5, 1999 | 05:35 AM
Dan's Avatar
Dan
Clutch chatter
I failed to mention it, but the flywheel was resurfaced the first time and runout checked. It was removed and rechecked last time too. We'll see later today if the fourth time is a charm. Nobody I've talked to can believe it's not working right. DB
Old Aug 5, 1999 | 06:04 PM
ole65's Avatar
ole65
Clutch chatter
If the fourth time is not a charm, then it is time to get a new, not remanufactured, Ford clutch pack. Others can make all sorts of claims but a new Ford clutch assembly is the way to go, especially with your troubles. Although pricey, there are few things worse than a chattering clutch.
Old Aug 5, 1999 | 06:58 PM
ray's Avatar
ray
Clutch chatter
I have never experienced the need to do so but I've heard stories of the bell housing and or tranny case needing wedges between them to correct alignment problems. Good luck, let us know what the resolve is.
ray
Old Aug 6, 1999 | 05:25 AM
Dan Blackwell
Guest
Posts: n/a
Clutch chatter
A guy in my office who, in his younger years, used to change right side rubber for Jimmy Hensley told me there was a time when clutches sometimes had to be shimmed to get equal clearances all around. He was talking older than mine though.
Maybe I need to be looking at this from a different perspective--it's keeping me off the street.
DB
Old Aug 6, 1999 | 05:30 AM
Dan Blackwell
Guest
Posts: n/a
Clutch chatter
Unfortunately, it is a new one--they all have been. And unfortunately it was pricey--$265 for the kit.
DB
Old Aug 13, 1999 | 01:22 PM
Dan B.
Guest
Posts: n/a
Clutch chatter
Just to let ya'll know, the fourth install is by far the best yet. I can even start off on a little incline without the clutch trying to grab, if I do it a little slower than I like to. It still ain't right, though. I've been driving on it for about a week now and it seems to be getting a little better...or I'm getting used to it. Thanks to all for the advice. I'll be back later with wheels and rear-ends and windshield wipers and who knows what else. DB
Old Aug 13, 1999 | 05:33 PM
merchey's Avatar
merchey
Clutch chatter
I gave up on a 3-sp because it had a bad input shaft bearing and other engine and steering gear conversion issues. I talked to someone that had similar symptoms whose main tranny shaft broke because of a bad input shaft bearing. when I inspected my flywheel, clutch parts, and pilot bearing, I came to the conclusion that the chatter was coming from the input shaft.
Old Aug 13, 1999 | 07:59 PM
FTE Ken's Avatar
FTE Ken
Clutch chatter
test
Old Aug 13, 1999 | 08:56 PM
Ben_E's Avatar
Ben_E
Clutch chatter
pdqford
16
Jul 24, 2019 06:07 PM
Boss300
Oct 31, 2009 01:31 PM
matt2491
Jun 21, 2008 08:55 AM
cchildress
Jun 4, 2008 08:16 PM
Bigredcrew
Mar 22, 2007 10:10 PM
