blower
Old Aug 13, 1999 | 04:44 PM
HOMER RUSSELL
Guest
Posts: n/a
blower
my blower for my heater is not working, how hard is it to replace a blower, my truck is a 79 ford f150
Old Aug 13, 1999 | 10:24 PM
DOUG TRACY
Guest
Posts: n/a
blower
IT IS A EASY TASK TO REPLACE THE BLOWER, IJUST RECENTLY REPLACED MINE ON MY 77. MY SUGESTION IS TO REPLACE ALL OF THE GASGETS ALSO. IU WAS ABLE TO FIND A KIT FROM FORD REPLACEMENT PARTS. JUST TOOK PART OF A AFTERNOON
Old Aug 14, 1999 | 12:08 AM
390fe's Avatar
390fe
blower
If your truck isn't ac equiped, it'll be much easier. I seem to remember a buddy's '78 with air, and him wishing he'd just pulled the fender off! You're in for a job! By the time you get it done, you'll wish you had a '67-72 F100. About three screws and five minutes max to change the blower motor out. Good luck!
Old Aug 14, 1999 | 12:42 PM
Fordman's Avatar
Fordman
blower
If you have AC you have to pull the whole unit out that houses the AC core and the heater core and the blower is in along with all the other stuff. Take the hood off!!! It makes this job so much easier and you arent always hitting your head and you can see what you are doing. There are 6 or 7 bolts that you have to pull out. 5 are accessed from the cab and the other two are in the engine compartment. You have to pull the glove box out too. You dont have to disconnect your AC lines but it is easier this way. Mine wasnt charged so I didnt leak any freon. Once you get the houseing out you can get to the blower relativaely easily. Going back in with the housing can be tricky. This can take about 1 really good day of work to change.
Fordman
Old Aug 15, 1999 | 01:32 PM
matt_1's Avatar
matt_1
blower
Brian460
Dec 18, 2009 10:49 AM
drpratt
Apr 14, 2009 09:50 AM
390 blower
Apr 4, 2008 04:59 PM
motorheadmach1
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 9, 2003 08:49 PM
