6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Edge Insight question
Old Feb 1, 2010 | 03:58 PM
RuralSurvivalGuide's Avatar
RuralSurvivalGuide
Bought an Insight monitor last week. When I start my truck it doesn't come on. I have to unplug then plug & it works fine. Is this the way it is supposed to work? Is there an easy fix, or do I need to call Edge for a fix?
Old Feb 1, 2010 | 05:04 PM
ruschejj's Avatar
ruschejj
Mine comes on every time I turn the ignition key, never had to unplug it before.
I also never mess with it so I don't remember the menu options but there may be a setting somewhere to configure. Not sure.
Did you do the initial set up where you select gas/diesel? Do you have to do that every time too?
Old Feb 1, 2010 | 05:21 PM
RuralSurvivalGuide
Yeah...Since I unplug every time I start it, it asks what type of fuel, and wheither I want the ensight settings or the ones I loaded. ( I guess its since I have to unplug it?)
Old Feb 1, 2010 | 05:40 PM
ruschejj's Avatar
ruschejj
Yeah, if you unplug you do have to select those things. I don't know what to tell you other than mine does not act like that. Sorry. Edge folks should be good to deal with.
Old Feb 1, 2010 | 07:27 PM
RuralSurvivalGuide
Ill call them tomorrow. Read on this or another forum, someone had the same problem. I wasnt able to find that thread though..
Thanx anyway.
Paul
Old Feb 1, 2010 | 09:48 PM
Softballdad's Avatar
Softballdad
I've never had to unplug mine. It starts up everytime I turn the key.
Old Feb 2, 2010 | 06:44 AM
F(NMN)P's Avatar
F(NMN)P
I installed the insight on my 2010 F350 and I have the same problem. Contacted Edge and was told they are aware of the problem but don't have a fix. This was back in Oct 09. I've called serveral times since and still no fix nor an estimated date. This last time I call, 15 Jan, I asked for a refund, was told they would get back, have heard anything yet! I'm looking for a good monitor/gauge system something like the Insight but that works, any suggestions?
Old Feb 2, 2010 | 11:50 AM
RuralSurvivalGuide
Dashdaq at Drew Technologies makes a real nice one, a little bit spendier though. I don't think you need to buy tunes with it, if you want to stay stock. I'm going to stay stock for the next few years for warranty. The Insight was priced right for a simple monitor, but I don't want to unplug all the time. You think they would at least exchange the unit for another that wasn't defective.
Old Feb 2, 2010 | 12:44 PM
waverunner800's Avatar
waverunner800
Mine also comes on everytime I turn the key on. Only unplugged it once about a week ago to do a firmware update, only to find it is up-to-date. When I plugged it back in, I had to the selection process, but not since. Something is not right with yours...
Old Feb 2, 2010 | 02:22 PM
RuralSurvivalGuide
Just got off the phone with Edge. "very unusual problem" was what he said. But after a couple more questions, he offered up to send me a new one with cable. Will see if the new one works in a day or so.
Paul
Old Feb 3, 2010 | 05:33 PM
F(NMN)P's Avatar
F(NMN)P
Paul that's great news, keep us posted if the replacement works. If it does I'll have to get them to replace mine!
Frank
Old Feb 4, 2010 | 07:56 PM
RuralSurvivalGuide
Geez... Received my replacement gizmo and harness in the mail today...but wait. Pluged both into my truck & it works fine. Shut it off, turn back on a few minutes later, same problem, the unit will not turn on. Tried new monitor old harness, new harness old monitor, does not work.
I'm starting to think this may be problem with the truck. '08s work, mine is a '09 Frank yours is a '10 & they don't seem to work...or its a software problem. Arrrgh!
I'll see what they have to say tomorrow. Sure is a cowinkidink that two have the same problem. It's gotta be something else. There I go thinkin' again.
Old Feb 5, 2010 | 10:41 AM
RuralSurvivalGuide
I talked to Edge this morning. They confirmed that it is a software problem with '09s an '10s. So now I'm basicly SOL. till they can find the glitch in their queery.
VONxRUBENxLA
May 23, 2013 09:20 AM
Lastwagen
6.7L Power Stroke Diesel
Jan 4, 2013 08:22 PM
villestrip
2004 - 2008 F150
Oct 6, 2010 06:57 PM
Kdr3885
Sep 18, 2010 12:35 PM
FordMan35
Aug 17, 2010 12:01 AM
