starting..
Old Feb 1, 2010 | 03:06 PM
Krisx125's Avatar
Krisx125
starting..
Down to the final straw....Did glow plugs...GPR..returned the week old GPR and got another one due to buzzing noise from the other one...Brand new batteries...It still wont start...or even try to start. Im aware that my ICP sensor is bad, and ive unplugged it. It fired up the other day and ran for a minute and idled rough and dropped out cylinders and died..then wouldnt start again. Its 25 degrees here..And all my other 7.3's started fine..What am i missing?
Old Feb 1, 2010 | 04:30 PM
Action4478's Avatar
Action4478
Do you have a thread that explains in more detail the problem...?...
Old Feb 1, 2010 | 04:50 PM
Krisx125's Avatar
Krisx125
No i dont. This has been an on going issue with my 97 F350. No mods other than 6637 and superchip. First i had a problem with my EPBV shutting all the time. So i unpluged that. Then it would start on a cold morning and run for a second and idle rough then stall..So i replaced the GPR with a standard. That made a buzzing noise, so i returned that and bought a Napa GPR-109. Then it still did it. So i replaced all glow plugs and it threw a code something about glow plug banks...Then i was told my ICP sensor was bad..So i unplugged that and it still doest like to start..
Old Feb 1, 2010 | 05:35 PM
Action4478's Avatar
Action4478
It sounds like a LPOP issue , or the oil is old (or is low). Next time it dies after starting it , look in the HPOP res , see if it is full
Old Feb 1, 2010 | 06:21 PM
Krisx125's Avatar
Krisx125
Pretty embarrassing, but my 7.3's have never given me an issue..So i feel stupid asking this..Where is the LPOP and HPOP? How do i check them? I searched around and the LPOP symptoms sounds similar to my issue...Any pictures of the pumps? Thanks for the info
Old Feb 1, 2010 | 07:47 PM
fordpride's Avatar
fordpride
HPOP res. front top center of eng. the res. is about 8 inches long 2inches wide it almost looks like part of the front eng cover there is a allen bolt on top to the right of it remove it to see oil level
MiamiPSD
Mar 7, 2013 07:25 PM
farmer ford
Dec 2, 2012 03:36 PM
Troy Banning
Jul 27, 2009 10:23 PM
kilapapipa
21
Feb 11, 2009 07:55 AM
the weez
Oct 17, 2006 08:20 PM
