door panel and dash repairs
Old Feb 1, 2010 | 01:56 PM
RRranch's Avatar
RRranch
What kind of glue will work fixing cracks and broken off clips on these things? Or is the plastic able to be welded at all? I've seen plastic welders before but never tried one. I got cracks and broken off parts all over the place in mine thanks to the kids slamming doors all the time. I think the next one to do it is going to walk. My doors work perfectly, no reason to slam anything at all.
Old Feb 1, 2010 | 03:30 PM
donbrown's Avatar
donbrown
A really good plastic welder is gonna cost several hundred dollars.
Living in the big city there are guys who travel to car dealerships and do nothing but fix cracks in molding / dashboards etc for under a hundred dollars ... they even blend the color to compensate for UV fading.
Last time I checked it was $50 for the first crack and $25 for each one 1-6 inches long.
The welder is gonna cost 200-400.
You can also go to a upholstery or furniture repair shop for vinyl.
Old Feb 1, 2010 | 05:30 PM
helifixer's Avatar
helifixer
if it isn't visible I just take my soldering iron and another piece of a panel (found at every wrecking yard) and weld it back together. use the iron and the filler just like welding with oxy/ace welder.
Old Feb 1, 2010 | 07:09 PM
tjbeggs's Avatar
tjbeggs
Its pricey for the gun and tips but panel bond is amazing! Its like JB weld but about 10 times better. I use it to fix all plastic breaks. Non visible ones that is.
Old Feb 1, 2010 | 07:44 PM
TimmyAbrams's Avatar
TimmyAbrams
Because of the the many cracks in my dash, I ordered a "Dash Mat" or a carpet dash cover. Should be in by the end of the week. Supposedly it is molded to the dash. If anyone's intersted, I can post a few pictures. Not a bad deal for less than $30 and it's from a reputable parts warehouse.
Old Feb 1, 2010 | 08:01 PM
fordpride's Avatar
fordpride
as far the cracks not sure but broken clips 60 sec. apoxy from wal-mart i put a broke off mirror back on my wife's car
Old Feb 2, 2010 | 12:38 AM
donbrown's Avatar
donbrown
Post a picture ... let us see what ya got.
Old Feb 2, 2010 | 09:58 AM
MagKarl's Avatar
MagKarl
Some of the trim plastic is molded ABS. I have fixed some by using ABS pipe solvent/glue. Don't use too much or it will not want to cure.
Old Feb 20, 2010 | 06:36 PM
TimmyAbrams
As asked in this tread, I'll try and post a couple of pictures of the "dash cover" that I ordered. The first one I ordered was incorrect. The company did not know about the 97 OBS 250. So, I sent it back, and received another one for a 96 F-250. There are several different styles, and this is the cheapest. I bought one for my wife's van that was $10 more, and is very nice.
Anyways,
Here.
Pre-Op
http://i425.photobucket.com/albums/p...k/DSCN1382.jpg
Post-Op
http://i425.photobucket.com/albums/p...k/DSCN1397.jpg
And the seat covers that I just got. They do fit nicely (much better than any of the other Universal Seat covers that I have used)
http://i425.photobucket.com/albums/p...k/DSCN1401.jpg
Old Feb 21, 2010 | 01:59 AM
TheBigGreenMachine's Avatar
TheBigGreenMachine
Just go to your nearest junkyard and get a whole new dash for 10 bucks. Works perfect, though they do normally need cleaning.
Old Feb 21, 2010 | 09:37 AM
Talyn's Avatar
Talyn
I personally cannot stand dash mats.
Big dust collectors IMO.
Anyways.
The one main pad that cracks on our dash on the passenger side is replaceable, so just replace it.
As for the in the door stuff.
A varity of things work that I've tried.
The best one is zip ties and a drill, depending on what your doing.
Contact cement for some things. i've tried silicone caulk to glue stuff. Usually for the Jute Matt.
I tried hot glue one time, but that is a bad idea, cause it just gets hot and melts haha.
best bet is some spare plastic to melt as filler and a soldering iron you dont mind trashing.
You can use zip ties as filler sometimes as well and a small pocket torch.
breezy5000
Sep 25, 2017 05:46 PM
beenaround
Aug 7, 2017 09:41 PM
F250_
19
Dec 20, 2016 11:34 PM
hath
Vehicles for Sale
Apr 26, 2016 10:53 PM
Bluey Zedoff
19
Apr 3, 2016 08:28 PM
