So now what?
Old Feb 1, 2010 | 09:18 AM
lonecountryboy's Avatar
lonecountryboy
So now what?
So I have been having problems with the tranny on my 94 F-150 with the 5.8L and the E4OD and pretty much have most of them worked out but one. The first was the filter fell off and was causing me all kinds of problems fixed that. Then the VSS went out and was causing me problems fixed that. The tranny shifts great now but when you first put it in gear in the morning it wants to start out in 4th. You manually shift it to first and manually upshift it is fine and after awhile it will start working correctly in drive. At the moment there are no codes and besides that one problem it works fine. So any ideas? MLPS maybe, but if that was acting up wouldn't it throw some kind of code? Kinda of at a loss here don't know if it is mechanical or electrical. I did some searching and some of the other posts were kinda of in that area but nothing definitive. So if anybody has the same problem or has had the same problem what did you do to fix it?
Old Feb 1, 2010 | 09:23 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/8...n-problem.html Have a look at the post by subford in this thread on testing the MLPS.
Old Feb 1, 2010 | 10:13 AM
rla2005's Avatar
rla2005
Also check the connector for the solenoid pack. No power to the pack will result in a 4th gear start.
Old Feb 1, 2010 | 03:22 PM
lonecountryboy
Thanks for the information.
MonroeHandyMan
Mar 9, 2015 03:01 PM
BJHB
2009 - 2014 F150
Nov 4, 2012 04:36 PM
jojeep
Sep 5, 2011 05:11 PM
laser92awd
1983 - 2012 Ranger & B-Series
Nov 21, 2005 02:10 PM
