94 trasmission problem
Old Sep 23, 2009 | 11:42 AM
redneck23ms's Avatar
redneck23ms
i have a 94 f150 302 e4od. yesterday after making a 4 hour drive from my hunting cmp back home my trasmission was having a problem. it would seem like it would miss a shift and drop into neutral. if i let off the gas and let the rpms drop back down it would shift and work fine. it did this several times. it only seemed to do it when very lightly pressing the accelerator pedal. it had also rained almost the entire 4 hours if that could be a factor. i pulled the codes this morning and all was fine. only got the 111 code for system pass. any ideas?
Old Sep 23, 2009 | 12:01 PM
subford's Avatar
subford
Check your MLPS.
Old Sep 23, 2009 | 12:55 PM
redneck23ms
well after looking at this i may have the 4r70w transmission since the plug on my mlps looks like that one. but i do have the overdrive button on the shifter. the mlps readings are within spec but most of them are closer to the upper limits according to the numbers listed here
Old Sep 23, 2009 | 01:39 PM
subford's Avatar
subford
I was thinking about the water and this TSB:
TRANSMISSION —AODE/4R70W—DIAGNOSTIC Article No.
TROUBLE CODES—WATER INTRUSION OF THE 95-3-13
MLP/TR SENSOR
TRANSMISSION—AODE/4R70W—POSSIBLE WATER
INTRUSION INTO THE MLP/TR SENSOR CAUSING
SHIFT CONCERNS AND/OR ENGAGEMENT
CONCERNS
TRANSMISSION—AODE/4R70W—SHIFT CONCERNS
AND/OR ENGAGEMENT CONCERNS DUE TO
WATER INTRUSION OF THE MLP/TR SENSOR
FORD: 1992-1995 CROWN VICTORIA
1994-1995 MUSTANG, THUNDERBIRD, E-150, F-150
LINCOLN: 1992-1995 TOWN CAR
1993-1995 MARK VIII
MERCURY: 1992-1995 GRAND MARQUIS
1994-1995 COUGAR
ISSUE The TR Service Kit contains:
Some vehicles may exhibit a shift concern and/or One (1) TR Sensor
an engagement concern due to water intrusion into One (1) Connector Assembly
the MLP/TR sensor and vehicle harness. There may One (1) “Red” Pin Separator Plate
also be a number of different DTC’s along with
those concerns. One (1) 6-Pin Grommet
Two (2) 4mm Spacers
ACTION Two (2) 8mm Spacers
Replace the MLP/TR sensor and vehicle harness
connector if signs of water penetration are evident. One (1) Instruction Sheet (I.S. #6951)
Refer to the following procedure for service details. PART NUMBER PART NAME
SERVICE PROCEDURE F5AZ-7A247-A TR Sensor Service Kit
1. Verify the customer concern.
OTHER APPLICABLE ARTICLES: 95-2-12
2. Perform normal On-Board Diagnostics. WARRANTY STATUS: Eligible Under The
Provisions Of Bumper To
3. Inspect the MLP/TR sensor for signs of water Bumper Warranty Coverage
contamination. And California Emissions
4. If water penetration is present and DTC’s have Warranty Coverage For
been set, replace the MLP/TR sensor and the 1995 Crown Victoria And
vehicle harness connector with the TR Sensor Grand Marquis, Mustang
Service Kit (F5AZ-7A247-A). (3.8L), Thunderbird And
Cougar (4.6L), And Town
Car
OPERATION DESCRIPTION TIME
950313A Perform Diagnostics And 2.0 Hrs.
Replace TR Sensor And
Replace Harness
Connector
PROOF 24-APR-00 TC4AT90 TC4AT90 PAGE 1
Article No. 95-3-13 Cont’d.
DEALER CODING
CONDITION
BASIC PART NO. CODE
7F293 08
OASIS CODES: 206000, 501000, 502000, 503000,
504000, 698298
frankcangi
Oct 3, 2010 06:12 PM
magnethead
Nov 29, 2007 11:37 AM
TexasGuy001
Nov 18, 2006 11:06 AM
ROKNTB
Oct 12, 2006 02:57 AM
studio502
16
Jun 12, 2003 01:28 AM
