Air cleaner configuration
Old Feb 1, 2010 | 08:58 AM
emgee's Avatar
emgee
Red face Air cleaner configuration
Does anyone have some pictures of how the air cleaner looks and is assembled for a 1980 F100 carbureted 300 six? Mine came in pieces in a box from the PO and some items seem missing. Thanks for any pictures or diagrams.
Old Feb 1, 2010 | 10:57 AM
AbandonedBronco's Avatar
AbandonedBronco
Hopefully these pictures help.
Old Feb 1, 2010 | 11:58 AM
Harte3's Avatar
Harte3
I think maybe on a F100 the air cleaner housing would be a direct mount on the carb and not offset like on AB's bronco.
Old Feb 1, 2010 | 01:48 PM
hoxiii's Avatar
hoxiii
Lord help anyone that needs directions on putting a pancake air filter together.
Every 1980 with a 300 I've ever seen used that offset mount. Earliest direct mount I've seen is an '83, when ford went to the feedback carburetor. Not saying I've seen them all, but asking for help I'd ASSume he has the offset filter.
Old Feb 1, 2010 | 02:25 PM
emgee's Avatar
emgee
Thanks AbandonedBronco. I was having trouble getting an idea about the general routing of vacuum lines etc. more than the actual assembly of the air cleaner. I wanted to assemble as much of it inside the house instead of the minus 30 C in the garage.
Old Feb 1, 2010 | 02:30 PM
AbandonedBronco
Ahhh.... THAT's the fun part. Fortunately, the entire vacuum line system can almost be assembled in one piece with the air cleaner and tubing intact. It can be difficult to get pictures though, since a lot of it routes underneath other parts, connects to the underside of the air cleaner, etc. There should be a factory sticker in the engine bay up by the radiator that shows the vacuum line routing.
Old Feb 2, 2010 | 10:57 AM
Harte3's Avatar
Harte3
My pre-feedback '83 had a direct mount air filter housing rather than the offset.
Old Feb 2, 2010 | 11:01 AM
AbandonedBronco
If I remember right, your '83 air filter housing was also about 15" - 20" across, unlike the 10" of the offset type. Maybe they didn't need to offset it anymore since they just made it bigger?
Old Feb 2, 2010 | 01:47 PM
Harte3's Avatar
Harte3
Unless there were clearance issues, the offset style could be a bit of a PITA. The original filter and housing on my truck would have been more than adequate had it fit the 4v carb.
Old Jan 1, 2020 | 06:35 PM
Shooter3's Avatar
Shooter3
Does anyone have the brace/bracket that supports the air cleaner housing to the block?
Old Jan 1, 2020 | 08:01 PM
Kramercd's Avatar
Kramercd
Not sure what one you need, I've been eyeing this one on ebay for awhile, just not sure I want to give what they are asking though. https://www.ebay.com/itm/NOS-1968-Fo...p/142727392004
Old Jan 2, 2020 | 05:13 AM
Shooter3's Avatar
Shooter3
Bracket
No sir. The one I need is a older one.
Old Jan 2, 2020 | 06:05 PM
john jamieson's Avatar
john jamieson
But where does the tall brown glass thingy go that is in AB's picture?
Old Jan 2, 2020 | 06:16 PM
Kramercd's Avatar
Kramercd
I haven't seen any like that. Then again I don know what mine is supposed to look like either, just that it should have one. I may make one for mine. Haven't seen @NumberDummy around lately, but with any luck he'll drop in and add some of his expertise to the topic, maybe let us know what style goes to what application.
I'd say in the off hand, unless it has poor circulation, prone to getting cold, then it'd go in the other hand.
Old Jan 5, 2020 | 08:52 AM
FuzzFace2's Avatar
FuzzFace2
I made mine and did not know it had a brace off the side as I started with nothing but a crappy 3" filter.
and yes it has been painted black.
Dave ----
