Starter Bendix Problems
Old Feb 1, 2010 | 08:02 AM
BigDude97's Avatar
BigDude97
Hello, I have a '97 F250 Powerstroke and have been having trouble with the starter. Sometimes the starter will not engage, it just just spins. I can turn it off and count to 10 and then turn it on and count to 10 before I put the switch in the star position and it will start. I might not have any more problems for two days. Then it will start again. I replaced the starter twice over the last year and it starts first time. Then does this all over again, starter is a NAPA lifetime. It has 232,000 miles on it and no ring gear noise at all when it is turning over. I added a extra ground directly to the starter from the battery, no luck. Added a new solenoid, no luck. Increased the size of the wire going from the starter to the solenoid, no luck. Any ideas? Help!!
Steve
Old Feb 1, 2010 | 08:04 AM
Talyn's Avatar
Talyn
Have you replaced the fender relay under the hood?
Old Feb 1, 2010 | 08:09 AM
BigDude97's Avatar
BigDude97
Fender relay? No, solenoid , yes. Where is fender relay?
Old Feb 1, 2010 | 08:24 AM
Talyn's Avatar
Talyn
Sorry, it is a solenoid. (doh!)
My bad.
Generally the one on the fender goes bad and causes your problem.
Old Feb 1, 2010 | 08:31 AM
BigDude97's Avatar
BigDude97
Yea, That was my first thought too. I replaced it with the heavy duty NAPA switch. How about the Park / Neutral switch and the stater key switch? Can they be cleaned or maybe need to be relaced? I tried jump starting the solenoid one time when it was stuck and it didn't help at all.
Old Feb 1, 2010 | 08:34 AM
Talyn's Avatar
Talyn
well, if the starter spun, and it didn't engage, then i doubt you have any issues.
Sounds like its not getting the signal to push in the plunger.
This is getting a bit beyond my knowledge base. So. =\
Old Feb 1, 2010 | 08:56 AM
BigDude97's Avatar
BigDude97
Thanks anyway! I plan on taking the bendix apart today and lubing it and also increasing the size of wire going to it.
Old Feb 1, 2010 | 10:32 AM
Welk49's Avatar
Welk49
i had some problems with a starter on mine a few months back. The bendix would not fully disengage until the truck had been running for 5-10 seconds. Made one hell of a racket and damaged my flexplate. Went through 3 different starters from the parts store until I finally got one that worked fine. I was very pissed off, but did get a new flexplate out of it. Hopefully you get it figured out.
Old Feb 1, 2010 | 07:18 PM
tjbeggs's Avatar
tjbeggs
Its the starter itself. If the starter spins there is nothing but the bendix drive that is the issue.
Old Feb 1, 2010 | 07:38 PM
TimmyAbrams's Avatar
TimmyAbrams
I know your pain with the starter spinning and not connecting to the flywheel. It just started happening to me today. I just replaced the batteries and cables, just to have this problem.
I'll pull it apart tomorrow and clean it, hopefully it will help. I'll let you know what I find BigDude. I'll try to take pictures with my phone also.
Tim
Old Feb 1, 2010 | 08:02 PM
yoslick's Avatar
yoslick
Don't take it apart, it's warranted, get a new one!
Old Feb 2, 2010 | 06:21 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Doesn't it sound like a missing tooth on the flywheel?
Seen (heard) this many times.
If you repalce it with another new NAPA starter and it still does it, I'd pull the inspection cover off and rotate motor by hand and make sure the flywheel is in good shape.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 13, 2010 | 08:05 PM
MONAVIERONJON's Avatar
MONAVIERONJON
same here on a 97 psd,went through a replaced all the battery cables,alt,and removed the starter to bench test it.hooked some jumper cables to a battery outside of the truck to inspect functionality of the bendix.Although it functioned well,it still spins when installed.a big ?!?!?!??!?!?!
Old Sep 13, 2010 | 09:44 PM
BigDude97's Avatar
BigDude97
Fixed My Problem
I took the starter off and the flywheel looked great. The bendix gear showed some wear, but I need to find out what was going on. I pulled the transmission back and took the ring gear/flywheel off and it had 3 worn spots on it where there were no teeth. I replaced the flywheel and put another starter on and now everything is perfect. I have another problem I can't figure out. I had to replace the fuel sending unit on the front tank because it would not regester. Now it has quit working again. You ever heard of this happening?
Old Sep 14, 2010 | 08:59 AM
Talyn's Avatar
Talyn
sounds like a bad wire.
