blows black smoke
Old Jan 31, 2010 | 12:41 PM
kdot's Avatar
kdot
blows black smoke
1988 f150 5.0,looks like a disel. Have changed IACT,idle air control,tps and O2 sensor.My next guest is pressure regulator.Any advice will help. Engine has over 300,000 miles
Old Jan 31, 2010 | 12:46 PM
Conanski's Avatar
Conanski
Yes check fuel pressure and pull the codes to see if the MAP sensor is flagged, but if no codes are thrown and everything else checks out the computer itself is suspect.
Old Jan 31, 2010 | 09:14 PM
ExtrmZ's Avatar
ExtrmZ
this is the same problem i have with my mustang. check the timing, to make sure its on, and to make sure its not bouncing around. my mustang retards instead of advancing, and its gets all loaded up.
Old Jan 31, 2010 | 09:48 PM
ri_truck_guy's Avatar
ri_truck_guy
There's an orange ground wire that connects to the very rear intake bolt on the drivers side. It's your O2 sensor ground. Make sure that isn't broken or corroded.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
