NO WAY!!!!!
Old Jan 31, 2010 | 04:27 PM
timberjack's Avatar
timberjack
How about checking your IPR harness? Fuel leaks in the area have been known to eat away at the wire insulation, or maybe just as simple as the little stamped steel nut has backed off, so the solenoid no longer gets it's power.
FWIW - both my truck's (95 and 96) tach have never really moved at all while i am cranking it over to start, so i've never really used that solely for diagnosis of a bad CPS.
Old Jan 31, 2010 | 05:27 PM
MADVAN's Avatar
MADVAN
Test with ign key in run and sensor unplugged.
Pin A-LB= ground. Ohm test 5ohms
Pin B-BR/W= 5 volts.
Pin C-DG= 12 volts
Bill
Old Jan 31, 2010 | 08:24 PM
scatgo's Avatar
scatgo
Pin C-DG= 12 volts
Bill
I got the 5v 12v but 0 ohms??? Any one know what the light blue wire goes to?
Old Jan 31, 2010 | 08:50 PM
Hussler's Avatar
Hussler
Light blue goes to the PCM pin #65, it's the ground.
If you mean (zero) ohms like the probes are shorted then you are OK.
If you mean (infinity) ohms like the probes are not shorted then the wire is bad somewhere.
Spec is 5 ohms or less.
Old Jan 31, 2010 | 09:06 PM
scatgo's Avatar
scatgo
Yea i am good. Got a solid ground. Any suggestions on what my next move should be?
Old Feb 1, 2010 | 07:20 AM
scatgo's Avatar
scatgo
The IPR is on the HPOP reservoir? Any one know how high the HPO pressure should be at cranking rpm's?
Old Feb 1, 2010 | 09:55 AM
Hussler's Avatar
Hussler
Spec Shows ...
ICP needs to report 500PSI and CPS needs to report at least 100 RPM cold to start. If CPS is not working IPR will never command over 400PSI.
Try unplugging the ICP sensor and start.
This will force the PCM to command the IPR to output 750PSI if CPS and IPR are working correctly.
Old Feb 1, 2010 | 10:18 AM
scatgo's Avatar
scatgo
Spec Shows ...
Will do but I want to make sure I am clear on a few things. The ICP is on the front of the drivers side head. it is the sensor where you do the 10k mod? And the IPR is next to the HPOP?
Old Feb 1, 2010 | 10:48 AM
Hussler's Avatar
Hussler
Correct ...
Old Feb 2, 2010 | 11:07 AM
scatgo's Avatar
scatgo
Spec Shows ...
No good. We looked at the CPS and it seems ok. I just unplugged the ICP and still wont start. Fuel pressure at cranking is 55. I would like to look at the IPR and IDM when I get home from work so If any one can give me some Info on how to test them I would be grateful. I don't have a pressure gauge to test HPO so I was thinking of loosing one of the nuts on the HPX and see if oil blasts out just to get a clue as to what the heck is going on. will report back. Thanks
Old Feb 2, 2010 | 11:18 AM
strokin'_tatsch's Avatar
strokin'_tatsch
have you tried putting in another CPS just for fun?? which CPS are you getting? if your getting the light grey one i could see it going out all the time... did you check the HPOP rez level? can you get a scanner to see what the ICP and IPR duty cycle % is????
Old Feb 2, 2010 | 11:28 AM
scatgo's Avatar
scatgo
The CPS I had to put in about five wees ago was black and made by standard. I just put a ford one in the other day. Think it was black but I am freaking colour blind so I will have to look into that. I didnt check HPOP res but will do when I get home from work. And no scanner just a edge evo code reader. Gota get back to work so Ill catch up with you all at around 4:30 and let you know what I find.
Old Feb 2, 2010 | 11:43 AM
  #28
cowmilker08's Avatar
cowmilker08
I hope I'm wrong, but that edge might be the problem.
Old Feb 2, 2010 | 04:07 PM
  #29
scatgo's Avatar
scatgo
I had the edge for over a year now and IIRC it is when you first try to load programs into the pcm is when things go bad.
Hey Strokin, you da man! I pulled the plug off the HPOP rez and stuck a screwdriver in there and the oil level was just over 2 inches below the top of the pump. I dumped about a quart of oil in it and the son a bee started right up. IIRC there is a check valve that is supposed to keep the oil in the rez but i am not sure where it is. Or is it the IPR that keeps the level up?
Old Feb 2, 2010 | 04:47 PM
  #30
MADVAN's Avatar
MADVAN
Check the oil level before you cold start it.
You could deplete the hpop res from cranking on it.
Bill
