Door locks posessed!?!?!?
Old Jan 30, 2010 | 04:20 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Today was the first time I have had this problem. The fob would not unlock the doors. I figured maybe it had a dead battery so I tried the spare...nothing. Once you get in and go, the locks cycle endlessly unlocking themselves over and over. It does stop, but then you get out and try to lock the truck and nothing. The lock buttons in the truck do nothing other than start the demonic posession of the locks running again.
I did a search but nothing seemed to fit this problem. I will probably start by pulling door panels to get at the switches so I can disconnect them one at a time. I will probably also check relays and see if I can swap them around to figure out if one is bad.
Any other suggestions would be great.
Old Jan 30, 2010 | 05:12 PM
alloro's Avatar
alloro
This same thing happened to my son's car. It turned out water had gotten into his driver's door switch and was shorting out the unlock side.
Perhaps you could use an oil extracter pump to draw the water out of the switch.
Old Jan 30, 2010 | 07:50 PM
Big Greenie
It was the drivers door switch. I have it unplugged for now. I managed to break the trim piece in the process so now I need the trim and the switch.
Old Jan 30, 2010 | 08:20 PM
fordtech08's Avatar
fordtech08
so you admit that an oil extracter does remove all the fluid from stuff
Old Jan 30, 2010 | 09:14 PM
alloro's Avatar
alloro
Originally Posted by fordtech08
so you admit that an oil extractor does remove all the fluid from stuff
I admitted nothing of the sort. Last I knew sludge doesn't build up inside of a switch.
Old Jan 30, 2010 | 09:23 PM
fordtech08's Avatar
fordtech08
actually the crap that builds up in a switch is allot like sludge especially when someone spills coke in it
Old Jan 30, 2010 | 09:25 PM
trsimmons25's Avatar
trsimmons25
The oil extractor comes out again! alloro and big greenie to your corners! LOL
Sleepyguy
Dec 20, 2016 03:07 PM
Glowplugger
Apr 9, 2016 07:24 PM
70FE250
Dec 14, 2015 10:26 AM
Christof13T
44
Dec 22, 2014 08:56 PM
HowieE
Apr 18, 2008 03:20 PM
