Engine year identification
Old Aug 30, 1999 | 08:38 PM
timpage's Avatar
timpage
I have just bought a 300 straight six, and am curious as to how I can tell what year and type of truck it came from. What numbers cast into the block will help me out?
Old Aug 31, 1999 | 01:17 AM
Stock Man
Guest
Posts: n/a
Because if you do you will answer it for yourself (The numbers cast in the block will help you out!) What are they in other words? Look just to the right of the water pump when facing it. There may be some die stamped numbers there. Otherwise, check the casting numbers down by the starter. Post what you find...no promises, but let's see what develops.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Aug 31, 1999 | 07:18 PM
timpage's Avatar
timpage
Ok, here's what I've got.
The numbers on the block by the starter are:
FOTE-6015-DA
The numbers on the timing gear cover are:
RF-E6TE-6059-BA
Help me "read" these numbers.
Old Aug 31, 1999 | 09:39 PM
Stock Man
Guest
Posts: n/a
Tim:
The numbers lead me to conclude an 80's model engine but I suspect you knew that much. Unfortunately, I have no resources for those years. So I cant help much. The other area for numbers I mentioned to you would be above the timing cover and to the right of the water pump when facing it. There should be a little exposed area on the block which has numbers stamped into it not cast. Check that spot. It may have a date code at least then you'd have a year.
Stock Man
Old Aug 31, 1999 | 09:50 PM
timpage's Avatar
timpage
I knew it was an '80s model, but determining a closer year would ease my curiousity. It probably isn't a big deal since I have an approximate time frame, but still would like to know.
Old Sep 1, 1999 | 04:03 PM
Stock Man
Guest
Posts: n/a
Tim:
Get your scraper and some cleaner and concentrate on that little area I mentioned previously; you might also look on the bottom of the block with the oil pan removed on the gasket sealing surface up in the front.
Have fun.
Stock Man
Old Sep 1, 1999 | 09:49 PM
timpage's Avatar
timpage
I found the stamped #. Here is what I found:
2J14
What do you say on this number.
Old Sep 2, 1999 | 06:14 AM
Stock Man
Guest
Posts: n/a
Year Month and day of the manufacturer on your block assembly. From everything else you posted it would appear you have a 1982 motor. Now what?
Stock Man
Old Sep 2, 1999 | 05:32 PM
timpage's Avatar
timpage
OK. Looks easy enough. Thanks for the help.
strawboss's Avatar
strawboss
4NIC8ING
1983 - 2012 Ranger & B-Series
Apr 3, 2017 02:06 PM
GAHIGHRIDER
19
May 23, 2016 07:34 PM
Harold Bruce Norrbom
Apr 8, 2015 12:26 AM
cjfarm11
Mar 23, 2011 11:16 AM
Thomsen
15
Feb 19, 2004 12:22 AM
