Sponsored by: Auxito
7700 questions
Old Jan 30, 2010 | 03:19 PM
Saber123316's Avatar
Saber123316
7700 questions
ok this may seem stupid but hear me out.
I am trying to figure out other than the frame and the transmission what is different on these trucks from a regular f-150 (the one im looking at has a 4r100)
Old Jan 30, 2010 | 03:41 PM
galaxie641's Avatar
galaxie641
The tranny is no different from other 5.4L F150's, the axles are beefier, 10.25 IIRC and I would assume the springs, I've never heard anything about the frame being any different though.
Old Jan 30, 2010 | 05:26 PM
93PGT's Avatar
93PGT
its been posted lots..
- 7 Lug Rims -
- They have a larger frame then the F150
- Bigger Brakes
- 3:73 10.25 sterling rear end from factory
- 4R100 Tranny
- Extra leaf in back
- Larger Torsion bars -
- Heavier towing capacity
- Weigh more -
- Larger rotors, I believe 13.5"
- HD shocks
- power steering cooler
- 4700 lbs rear axle
- HD rad, thicker
- HD alternator
- HD battery
- LT tires standard, load range D
- the tranny is the same as a F250 SD and the F350 SD which was behind the v10 and deisel 1000 lb torque capability
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
also, read the door jamb sticker. If the axle code begins with a letter, it's LSD. Example - B6 is a 3.73 LSD, 26 is an open 3.73. If the last number is other than 6, then you have something other than 3.73's. The tranny code is E for a 4R100, U for a 4R70W.
Old Jan 30, 2010 | 05:53 PM
1991fseries's Avatar
1991fseries
- 7 Lug Rims -
- Bigger Brakes
- 4R100 Tranny
- Weigh more -
- HD shocks
- HD rad, thicker
- HD alternator
- HD battery
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
7700lb, is the GVW, not the payload.
Old Jan 30, 2010 | 07:34 PM
Saber123316
WOW...
Beefy truck for a f-150.
Old Jan 31, 2010 | 09:22 PM
cogden's Avatar
cogden
The 5.4 7700's and F250LD's should have the 4R100 whereas trucks with the 4.6 have the 4R70W.
Old Jan 31, 2010 | 09:40 PM
fordf150farmer's Avatar
fordf150farmer
so is the difference in the leaf packs just the extra leaf? will the leaf pack from a 7700 fit a standard f150?
Old Jan 31, 2010 | 10:03 PM
cogden's Avatar
cogden
I'm not completely sure but I think the 7700 leafs are the same length, I do know that they are the same width (2.5 inches).
Old Jan 31, 2010 | 10:07 PM
fordf150farmer
thanks it has always bothered me.lol i kinda want to do a swap because i occasionally need the extra capacity, but not enough to justify a bigger truck
Old Jan 31, 2010 | 10:18 PM
fishb8's Avatar
fishb8
- 7 Lug Rims -
- Bigger Brakes
- 4R100 Tranny
- Weigh more -
- HD shocks
- HD rad, thicker
- HD alternator
- HD battery
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
Mine also has a tranny cooler on it, not sure if this was standard or aftermarket
Old Feb 5, 2010 | 05:47 PM
93PGT's Avatar
93PGT
oh ya, mine has the tranny cooler too, forgot about that... the rear leaf springs are the same length and width 2.5" just with one extra leaf... it took me a while to find rear add a leafs for the truck cause i thought they were different than regular f-150's but they are the same.
ya it is a beefy truck, best truck i have ever owned. i wouldnt be able to replace it, i'd have to go for a superduty with a diesel in it if anything.
Old Feb 5, 2010 | 06:40 PM
cogden's Avatar
cogden
I agree completely! Instead of upgrading to a superduty, my truck is getting a V-10 this summer.
Old Feb 5, 2010 | 09:20 PM
Ultramagdan's Avatar
Ultramagdan
That should be an interesting marriage. You must be pulling a trailer a lot to do that.
Old Feb 6, 2010 | 08:54 PM
cogden's Avatar
cogden
Yeah, I usually have trailer-full of equipment or logs behind me.
Chuck P.
Jan 13, 2012 05:59 AM
AlM
1978 - 1996 Big Bronco
Dec 10, 2010 08:14 PM
mavman
1997 - 2003 F150
Mar 5, 2002 11:59 AM
beartracks
Sep 14, 2001 03:29 PM
