Blinker shorts out
Old Jun 16, 1999 | 12:55 PM
Chuck P.'s Avatar
Chuck P.
Blinker shorts out
Old Jun 17, 1999 | 08:41 AM
Fordman's Avatar
Fordman
Blinker shorts out
I have a problem with the blinkers (turn signals) in my pickup. They worked fine when I bought the pickup and worked fine for about a month. Then I was coming home one night and they shorted out. I didnt think much of it so I put another fuse in and they worked for about 5 seconds and the fuse blew again. Can anyone tell me the way to find a short in the blinkers system so I can get blinkers and stop the frustration?
Thanks
Fordman
Old Jun 17, 1999 | 11:53 AM
jowilker's Avatar
jowilker
Blinker shorts out
Fordman, I can, you have a wire with the insulation not covering a spot and it is touching the frame. Where is it, I haven't a clue. I would park the truck somewhere that you gan get under it. Start at the back where the wires come down from the tail lights and inspect the wire. Do both sides and after the two come together, follow all the way to the fire wall. I'll bet you find your problem by then. There is just a much higher chance of it being near the rear, and somewhere that the wire bends around the chassis. Look for places where someone may have repaired the line and there is loose tape.
John
Old Jun 17, 1999 | 04:04 PM
ray's Avatar
ray
Blinker shorts out
If I were to troubleshoot this problem I would start by pulling all bulbs and checking the sockets for corrosion. Clean the sockets, leave the bulbs out and see if any fuse blows. I've seen bulbs cause some strange problems. Don't overlook the posibility of the flasher unit being bad. Determin if the problem is with the turn signals and flashers also? Good luck
ray
Old Jan 12, 2012 | 01:50 PM
thekingofcows's Avatar
thekingofcows
One method to locating shorts is to unplug wiring harness starting with say the taillights, harness at the rear of the truck. Try blinkers, if the new fuse blows, then the short is closer to the cab, unplug connector at the cab. If it still shorts the problem is in the cab. This easy enough and requires no multimeters or special tools. Once you isolate the section of harness the short is in, find the short and repair it.
You can do the same thing with a meter by checking continuity between problem circuits and the frame or other ground, but it requires the use of meter (obviously).
Old Jan 12, 2012 | 08:29 PM
fmc400's Avatar
fmc400
MSEE
I'm guessing after 13 years, he probably moved on
Old Jan 13, 2012 | 05:59 AM
77393's Avatar
77393
LOL, yeah he might have them fixed by now. Good info anyway.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
