vin decoding, please
Old Jan 30, 2010 | 12:23 AM
72f250CS's Avatar
72f250CS
I did numerous searches, got nowhere. I chased all the links people have put on here, got nothing. can someone please decode this or give me a link to one that works for pre-'82.
F25YKV24089
'75 F250 2wd extended cab ranger 390 automatic,
thats all I know of it so far and thats just by looking at it. Thanks in advance.
Old Jan 30, 2010 | 12:56 AM
torquemeister's Avatar
torquemeister
From FTE's website (at top of page under Articles/Specs):
Your VIN number: F25YKV24089
Your Model Year is August 1974.
Truck Series: F250 2 Wheel Drive
Engine: V8 - 360cid, 2BBL carb
Assembly on: Kansas City, MO
What else do you want to know about it?
-Chris
Old Jan 30, 2010 | 11:17 AM
1969furd's Avatar
1969furd
will the vin tell me the gear ratio's on my truck?
if so here is my vin
f25hefc0085
Old Jan 31, 2010 | 03:09 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The VIN won't tell you the axle ratio.
On the drivers door is a metal plate (warranty plate) just below the lock. This will have an axle code on it along with the VIN number. That will give you the original axle information including ratio.
Problem, on trucks this old the door or axle (or both) could have been swaped out by a previous owner.
If you post the info on the tag I can decode it for you. It will tell you the original paint, interior, axle, etc.
Old Jan 31, 2010 | 09:14 AM
mikeo0o0o0's Avatar
mikeo0o0o0
This is what your VIN number decodes as:
F25HEFC0085
F25=F250 2WD
H= 351 2bbl V8 engine
E=Mahwah Assy. Plant
FC0085=1979 sequential serial number
Old Jan 31, 2010 | 04:55 PM
73supercamper's Avatar
73supercamper
i was wondering if i could get some help with my VIN for a 1973 truck i just bought. the vin is: F35JCS40857. i beleive the data plate numbers are: S6 43 F354 4 36J G A. but i am not sure the order because i only have the the warranty identification card with me. thank you for any help.
Old Jan 31, 2010 | 06:49 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check your other post, I decoded it there for you.
