Question on cooling fluid
Old Jan 29, 2010 | 08:43 PM
teppler's Avatar
teppler
Just thinking about the recomended flushing of cooling system. If you tested coolant and it showed nitrite, molybdate and glycol all within limits and then you strained it thru some fine filter and found no sand grit why change the coolant?
Old Jan 29, 2010 | 09:02 PM
bismic's Avatar
bismic
What is the silicate level?
Old Jan 29, 2010 | 09:10 PM
teppler's Avatar
teppler
Have no idea my questions were hypothetical, but wouldn't silicate level show if you strained sample thru a fine filter
Old Jan 29, 2010 | 09:17 PM
bismic's Avatar
bismic
The Gold coolant has silicates in it for cavitation erosion/corrosion control. These can get depleted with time and exposure to temperature (also with exposure to combustion gasses). Some of the "casting sand" folks find is no doubt some of the silicates coming out of solution. When it does, you have less protection from cavitation damage - primarily around the water pump.
I certainly don't know the levels that are good and thse that are bad. However, I do know that heat will deplete the additives. I think the EGR cooler plays a role in that - especially if the oil cooler starts getting plugged.
Personally, I would be conservative and flush it at 50k regardless what the analysis looked like. I do not know if that is overkill or not. I know it helps, just don't know how much.
Old Jan 29, 2010 | 09:21 PM
teppler's Avatar
teppler
Thanks for the response and good info.
Old Jan 30, 2010 | 12:10 PM
Cowboy65's Avatar
Cowboy65
Coolant flushes every 50K miles are cheap insurance for the dollars spent, IMO.
