79 Ford F150 Dashboard
Old Sep 7, 1999 | 03:34 PM
GREG050156's Avatar
GREG050156
Hi,all. I'm restoring a 79 f150 4wd and the dasboard is faded, still solid though. Local Ford dealer said they are obsolete. Has anyone ever tried the so called ' vinyl paints, and if so, does the paint last and how do you maintain the finish ? thanks a lot for any feedback,
Old Sep 7, 1999 | 03:51 PM
Marty's Avatar
Marty
When I changed the color in my '73 (2yrs ago) from brown to black, I went the cheap way and just used regular spraypaint and it still looks good. Just windex or armourall shines it up. I've seen the dash pads advertised in catalogs like JCWhitney, Dennis Carpenter Reproductions and LMC Truck. I have not personally used one, but have heard they look original.
Old Sep 9, 1999 | 12:43 PM
Steve's Avatar
Steve
Yup, most of the vinyl paints work well. I have painted a couple of dashes and some door panels with it and they seem to stand up well. You can get the paint in aerosol cans but I prefer to buy it in a can and use the spray gun to apply it. The key to is to clean the part that you are about to paint with the recommended cleaners first. I would suggest that you remove the dash to paint it. You may have to apply the paint in several light coats in order to cover up a change in color or to achieve a consistent coverage over the faded areas.
Later, Steve
Old Sep 11, 1999 | 05:35 AM
GREG050156's Avatar
GREG050156
Thanks for the info, I checked the prices at LMC and Dennis Carpenter's and at 290.00 a pad, I went with the paint. Bought it at a local auto upholster shop and it went on good. Looks like when am done with this truck, I could buy a new 99 2wd with the same money, but I lke the old fords better, just having sticker shock on what it is costing for parts on these old trucks. thanks again,
Old Sep 11, 1999 | 05:44 AM
GREG050156's Avatar
GREG050156
Thanks for the advice, I used the vinyl paint and it looks good, hope it lasts a while till I can get a reproduction unit, appreciate the reply. Wished I had found this site BEFORE I started restoration of this truck. I might have found out from the people that have already retored these old trucks, just how expensive it was going to be, thanks again
Old Sep 11, 1999 | 07:58 PM
BigBrownTruck's Avatar
BigBrownTruck
Corpsman24
Paint & Bodywork
Oct 3, 2012 10:23 PM
Roelito78
Aug 20, 2010 02:57 AM
Greg 79 f150
Paint & Bodywork
May 16, 2004 08:13 PM
gota_metseta
Nov 9, 2003 03:08 PM
katman3262
Colorado Chapter
Apr 8, 2003 06:53 PM
