door gasket replacement
Old May 6, 2004 | 09:00 PM
Greg 79 f150's Avatar
Greg 79 f150
Putting my 79 back together after I painted it, and I am replacing all window and door gaskets . The new door gaskets will not let the door close tight and latch. It will close to the first latch click, but has to be pushed HARD to get to the final latch click. I have always been fond of the way the old 79 doors closed and latched with that Ford magic "click". So, slamming a Ford p/u door is not in my vocabulary. Any tips on getting these new door gaskets to flatten out and gimme my "click" back ??
Old May 6, 2004 | 09:38 PM
Geneoh's Avatar
Geneoh
You might try to lossen the striker inside the door jamb, just a little bit.
Geno
Old May 7, 2004 | 12:54 AM
Aekisu's Avatar
Aekisu
<cr>
Slam the door tight, set it out in the sun, and let it cook for a few days.
Old May 7, 2004 | 05:17 AM
Greg 79 f150
thanks guys for the replies, I adjusted the strike pins with the gaskets off, so when the doors are in the fully latched position , the outside of the door skin is flush and even with the outside of the cab all the way around. So, I think I have the pins where they need to be, if I let them out, I believe my doors when latched up ,would then hang out past the cab. I heard somewhere that a good coat of vaseline on the rubber may soften them. Any truth to that one, other than just making it easier to slide in and out of the truck ? We are putting the engine in this Sat. so its on dollies for another week. By then, it should be good and warm out and I will do the bake thing. I just got to remember to take me a few cassette tapes , a cooler of cold drinks , and a sweat towel in to the cab with me. I cant stand the thought of leaving the babe out in the hot sun by herself,
Old May 16, 2004 | 07:19 PM
scottsheppard's Avatar
scottsheppard
Red face Door Seals
Hello, I have a 78 F-250...4X4...will be painting too...where did you get the seals from?
scott
Old May 16, 2004 | 08:13 PM
Greg 79 f150
At my local Ford dealer when they still had them back 3 years ago. I see that dennis carpenter, autokrafters, stores like those carry them now.
pwjackson42
Apr 10, 2014 06:11 AM
dawolverine
Oct 29, 2010 12:21 PM
Showpanther
Aug 14, 2010 08:02 AM
ghall
Jul 18, 2007 10:14 PM
tombob
1978 - 1996 Big Bronco
Dec 27, 2000 07:26 PM
