Sponsored by: Real Truck
Telescoping Mirrors
Old Jan 29, 2010 | 12:19 PM
rowley's Avatar
rowley
Telescoping Mirrors
Good Afternoon.
I just bought a 1999 F-250 4X4 and was wondering about the mirrors. It may sound silly but I thought that they all moved in and out for trailer towing. I can't seem to get them to move in. Do they or do they not telescope on this year of truck.
Old Jan 29, 2010 | 12:21 PM
wk4bg8s's Avatar
wk4bg8s
Some of these are manual, grab and pull out. Mine are electric, and the truck has a button on the armrest that controls this. Hope this helps a bit...
Old Jan 29, 2010 | 12:24 PM
rowley's Avatar
rowley
Tried pulling and pushin on them and they seem not to move at all. I think they look silly all the way out like that, and I don't see and button on the arm rest other than the one to adjust the mirror it self.
bryyce62's Avatar
bryyce62
They should. Don't expect them to move a foot or more though. Mine has 3 posititons. About an inch or 2 apart. Grab the inside of the mirror housing between the two posts & give a little tug. If that doesn't work, push it toward the door.
There are no buttons, it's done manually in '99
Welcome to FTE, BTW.
Old Jan 29, 2010 | 12:38 PM
rowley's Avatar
rowley
Nope, these suckers are stuck. Maybe some WD-40. Do the supports push in th mirror or the door so I know what to lube. All the mirrors do push in though right.
Old Jan 29, 2010 | 12:51 PM
89CrewCab's Avatar
89CrewCab
Quit trying. The TT mirrors in 1999 DO NOT telescope.
Old Jan 29, 2010 | 12:52 PM
rowley's Avatar
rowley
Thanks.... Thats what I thought.
Old Jan 29, 2010 | 01:50 PM
sjgordo's Avatar
sjgordo
Post
My 99 F250 has telescoping mirrors!
Old Jan 29, 2010 | 01:57 PM
rowley's Avatar
rowley
Well mine don't seem to want to move in or out so I will assume that they don't, unless someone can show me otherwise. Thanks for the help.
Old Jan 29, 2010 | 02:11 PM
BillyBob69's Avatar
BillyBob69
My 99 DID NOT telescope. I got a set of mirrors from a 2005 that telescope, power mirror, turn, marker lights and heat. $100 and they mounted right up...work great. Got them from another member on this forum that put actual Semi truck mirrors on his 05. Check around...you can find a good deal if you shop around enough.
Old Jan 29, 2010 | 03:17 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
Ebay has all kinds of them.I would stick with oem,aftermarket ones are no good.They look the same but quality is not as good.
Old Jan 29, 2010 | 03:32 PM
ameinig's Avatar
ameinig
My 1999 mirrors did not telescope or fold forward. Only backwards. The spot mirror on the bottom was not adjustable either.
Old Jan 29, 2010 | 03:43 PM
BillyBob69's Avatar
BillyBob69
Ditto......
Old Sep 10, 2011 | 10:10 AM
JBronius's Avatar
JBronius
2008 F250 SD DIesel- how to change Mirror Marker Lights?
Ford Manual does not show how this is done. I see behind the mirror some clips- do these need undone or can you just remove the amber cover with a screwdriver?
Old Jan 26, 2021 | 07:48 PM
Jayson Childs's Avatar
Jayson Childs
Originally Posted by rowley
Good Afternoon.
Thank you for the question... I was wondering the some on our '99 350
