replacing a fuse panel-need help!
Old Jan 28, 2010 | 07:15 PM
steekers's Avatar
steekers
As a new member, I have been looking for posts on replacing my plastic fuse panel since the one on my 1989 Super Duty flatbed dually is damaged (melted) at the heater/AC fuse position (a 30 Amp fuse). I also need help in restoring the key lock cylinder which is missing.
I read in one thread that some prefer using a separate push-button glow plug activation switch instead of the stock key and WTS light. This is what is in my truck now and wonder if I should go back to the stock method.
Any help or what posts I should read is appreciated.
Old Jan 28, 2010 | 07:36 PM
WarOzz's Avatar
WarOzz
If your talking the fuse panel under the dash it just a couple screws... unplug it and install replacement.
As for the ignition lock and push button gp... if the po installed a push button system the chances are your controller box is dead, that box is $100 to $150. I myself would fix it (and did just recently), I like things to operate as intended but if your in a money crunch and the system you have is working then why mess with it.
Old Jan 28, 2010 | 07:59 PM
steekers's Avatar
steekers
fuse panel
I mean the whole fuse "block" (Ford calls it a Fuse Panel) that has all the wires going to it on one side and the actual fuses on the other side. This fuse "panel" has color coded wires going to it. I noted where they go and then cut all the wires and removed the block. I would like to post a pic but not sure if I can as a new member.
I notice that there are unused slots on the fuse block. My Owners Guide shows the Econoline and F-Series models uses more of the slots that the F-Series Super Duty Commercial Stripped Chassis. There are fuse slots that are common to all the series.
How do I post some pics of my findings???
Old Jan 28, 2010 | 08:05 PM
WarOzz's Avatar
WarOzz
It's normal for not all slots to be used. Match up the wires and you should be ok.
You can upload a picture to your gallery and use it to post here, pm me if you need help with that.
Old Jan 30, 2010 | 10:11 PM
steekers's Avatar
steekers
fuse panel harness no longer available
Today I went to my Ford dealer to check on some parts and was of course blown away by the prices (and availability) of 1989/90 parts for my Super Duty. The plastic fuse panel is not available by itself and must be obtained (from Ford part E9TZ14401J) as a whole wire assembly. However, there are none available in the country so I went to the wrecking yard and got one for $75. No guarantees from a wrecking yard on wire assembly, but I had no choice.
Michael
64DarkHorse
Feb 21, 2015 04:50 PM
BrandonT71
Aug 2, 2013 07:52 PM
Tanner2255
Dec 16, 2011 08:52 PM
jimmmack
Nov 21, 2010 07:46 PM
Big Green Machine
Jan 31, 2008 08:49 AM
