My 72 F750 fuse panel is rusted up really bad and none of my brake lights or turn signals work. I was thinking about replacing the panel and wondered if any panel would work or if I need a Ford specific one. I haven't done a lot of work like replacing these so any specs on what to get will definitely go a long way to help me.
i would redo the whole truck. makes it alot safer and everything works. you can get kits between 200 and 800. i couldn't see wasting my time doing the panel when all my wires were in bad shape. if your sure you just want to do the panel, you should be able to get a universal one with enough fuses for your truck.
gl
mark
I've heard about kits but haven't looked much into them. Any direction you can provide? This is just an old work truck that doesn't get driven much so I would say something on the lower range ($200 to $300) maybe.
C7TZ-14A067-B .. Fuse Panel
Fits: 1967/69 F-N-NT-T500/1000
Fits: 1970/72 F500/750
This is a different fuse panel than the F100/350's use.
FTE sponsor GREEN SALES has 2 of these fuse panels NOS (new, old stock) available: = 800-543-4959 EST.
Green Sales sells new, old stock Ford obsolete parts.
I added a blade type (ATC) fuse block in my F-100. It came out of a late 80's junkyard camaro.All the spaces were labeled,I wired them to a terminal strip.Easy to add or change device locations that way.Worked out great and cheap ($0.00)
John i have seen your "In the cool still quiet hours of night, you can hear chevies rusting away." many times and i just have to say that that is my new fav quote.
Sorry i will let you guys get back to your fuse box topic now.
well if i judged it by the amount of rust on my truck compaired to my buddies chevy i would say yes. if you rock his truck just a little you have about a pound of rust and other crap fall off.
My other quote would be "Only little boys wear bowties."
