351w build...
Old Feb 11, 2010 | 03:50 PM
nstueve's Avatar
nstueve
OK so I ran the numbers today and Summit may get my business... It was $540 for the local guy to sell me a kit with his Erson Cam (moly rings and flat pistons 8.7:1 compresson) in it. Not sure the entire kits contents may not have had lifters or timing or 1 piece oil pan gasket... Any how I called Summit...
Premium 0.030 over kit
Flat pistons (compresson boosted to 9.17-1 with 63cc head... not sure if 63cc is stock?????)
Moly rings
Sealed power gasket set
Berings
Summit Racing Lifters
Comp Cam 35-255-5
Comp Cam Mag Double Roller Timing
I also added a Ford 1 piece oil pan gasket (Hate those 4 piecers!!!)
(they took out cam bering and freeze plugs -$30 off kit)
All for $660... $120 more than local machine shop but I get all the parts I want... May not be in budget for headers now but I can do that later.
Thanks guys for making me check myself before I did something stupid! I am wondering what kind of HP boost I will get from this combo if I put headers on, eliminate the cat, and run 2.5 in exhaust... I think this will all work under my SD limitations... any thoughts???
Old Feb 12, 2010 | 12:09 PM
Conanski's Avatar
Conanski
Yeah that sounds good and your CR is right on the money... E7's generally have 62-64cc chambers.
Old Feb 12, 2010 | 02:44 PM
nstueve's Avatar
nstueve
good! I didn't get any replies so I just ordered it all. I added a Melling Heavy Duty Intermediate Drive Shaft to replace the stock oil pump shaft. Also, 2 qts of Royal purple break in oil and a Moroso oil priming extention for my drill only b/c the engine might sit for a month or so till I get the money to do the C6 tranny).
lesoster
37
Jan 10, 2020 02:18 AM
351Cleveland C4
May 15, 2013 12:49 PM
screaminford
30
Feb 28, 2011 11:01 PM
Fordmclovin
19
Jan 19, 2009 03:28 PM
grumpy44
Jul 25, 2004 09:21 PM
