IAC Sensor Question
Old Jan 28, 2010 | 07:55 AM
hawgystyle's Avatar
hawgystyle
IAC Sensor Question
my idle on my truck was realy high so i unpluged the IAC motor and the truck runs fine. is it safe to drive around like that or is there something i can do to fix it. ive already replaced it and it does the same thing.
Old Jan 28, 2010 | 08:44 AM
hav24wheel's Avatar
hav24wheel
Did u replace it with new one, or a used one? Also, they don't like to be cleaned.
Old Jan 28, 2010 | 09:18 AM
Conanski's Avatar
Conanski
That indicates your TPS is bad.
Old Jan 28, 2010 | 01:06 PM
hawgystyle's Avatar
hawgystyle
whats the TPS on my truck?
Old Jan 28, 2010 | 01:17 PM
hav24wheel's Avatar
hav24wheel
Throttle position sensor... its on the throdle body.
Old Jan 28, 2010 | 01:26 PM
hawgystyle's Avatar
hawgystyle
how can that be replaced and how much does that part run for
Old Jan 28, 2010 | 01:29 PM
hav24wheel's Avatar
hav24wheel
Two screws and a plug. price, no idea.. Have you pulled codes at all? that will tell you forsure whats wrong.
Old Jan 28, 2010 | 01:34 PM
hawgystyle's Avatar
hawgystyle
well im not sure how to pull codes. im starting to think that i replaced the TPS and not the IAC. where is the IAC located?
Old Jan 28, 2010 | 01:41 PM
hav24wheel's Avatar
hav24wheel
on the side of the throddle body, TPS, is on the bottom of the throdle body.... There is a plug on the drivers fender by the hood hinge/spring. go to a parts store, and they can help you pull codes...
IAC pic
TPS pic
Old Jan 28, 2010 | 02:27 PM
hawgystyle's Avatar
hawgystyle
alright thanks, ill take a look at that
Old Jan 28, 2010 | 04:12 PM
ExtrmZ's Avatar
ExtrmZ
the TPS could be out of adjustment too.
Old Jan 28, 2010 | 09:02 PM
hawgystyle's Avatar
hawgystyle
well i found out that i did replace the TPS and my first one was ok as well. i found out what really is my IAC and im gonna need to replace that and hopefully it will idle properly then
revans9295
Feb 21, 2012 08:56 PM
wacp2
1997 - 2003 F150
Mar 25, 2010 02:17 PM
f150plow
Dec 3, 2006 05:39 PM
1990Fordf150v8
Oct 30, 2003 02:56 PM
dbuck50
Oct 25, 2003 10:19 AM
