Sponsored by: Auxito
BAD IAC Valve
Old Mar 24, 2010 | 03:18 PM
wacp2's Avatar
wacp2
BAD IAC Valve
Can a bad IAC valve cause my truck to idle so low it would turn off. If it does i have to replace the valve
Old Mar 24, 2010 | 04:34 PM
Ultramagdan's Avatar
Ultramagdan
Yes, it can. Lots of discussion on this with some cleaning it and others replacing it.
Old Mar 24, 2010 | 09:27 PM
Podaso's Avatar
Podaso
Cheaper to clean it, but better to buy a new one. And it's only a 20 minute job to replace it.
Old Mar 25, 2010 | 07:40 AM
benningstspeed1.0's Avatar
benningstspeed1.0
don't waist your time cleaning at best it just buys you some time.
Old Mar 25, 2010 | 02:17 PM
Dave G.'s Avatar
Dave G.
I've replaced 4 IAC's in the last 3 years. I beginning to think that there is a circuit problem. Of the 4 changes (now on the 5th valve), Ford dealer replaced one of them because I couldn't believe that another one went bad in less than a year. As I suspected, it WAS bad, and according to the mechanic, it failed the pin test. All the others that I checked/replaced, also failed the pin test.
Usually, when one goes bad, snapping the gas pedal to the floor as soon as the engine fires, seems to make it work again. That gets old in a hurry.
Dave
SatinBlack03
Modular V10 (6.8l)
Jun 19, 2016 04:18 PM
PRIMERED79 SHORT BED
17
Feb 22, 2014 09:02 PM
wingzam
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 16, 2013 08:00 PM
carlsson
Dec 11, 2011 04:21 PM
zeppln1
Jul 18, 2004 10:38 PM
