my idle on my truck was realy high so i unpluged the IAC motor and the truck runs fine. is it safe to drive around like that or is there something i can do to fix it. ive already replaced it and it does the same thing.
on the side of the throddle body, TPS, is on the bottom of the throdle body.... There is a plug on the drivers fender by the hood hinge/spring. go to a parts store, and they can help you pull codes...
well i found out that i did replace the TPS and my first one was ok as well. i found out what really is my IAC and im gonna need to replace that and hopefully it will idle properly then
