Sponsored by: Real Truck
still can't find the plug
Old Jan 26, 2010 | 10:33 AM
in heat's Avatar
in heat
well I have looked all over for the plug for the fog light harness and can't find it but when I do does anyone know where the post is to convert it to stay on with the high beams?
Old Jan 26, 2010 | 02:31 PM
Furian's Avatar
Furian
You Keep What You Kill
Off topic... Are those Bushwacker "Cut-Out" fender flares on your truck?
Old Jan 26, 2010 | 05:39 PM
in heat's Avatar
in heat
stampede (e-bay) not cutouts but look cool don't they
Old Jan 26, 2010 | 06:45 PM
Wagion's Avatar
Wagion
The old cut one wire ground it and done high beams on with fog doesn't work for 08 and up. There is a proposed way to do it I would have to find the post I am to much of a chicken shat to try it on my truck but if you want to try it and it works I'll do it to I'll try and find the post.
Old Jan 26, 2010 | 06:55 PM
Wagion's Avatar
Wagion
https://www.ford-trucks.com/forums/8...ml#post8006937
Old Jan 26, 2010 | 08:10 PM
in heat's Avatar
in heat
sounds like too much work to do that mod I really don't use the high beams anyway lots of traffic I live near portland
Old Jan 26, 2010 | 08:26 PM
Seaside's Avatar
Seaside
Portland, ME? How have I never seen that truck around. Pretty cool what business is it for?
Old Jan 26, 2010 | 10:22 PM
in heat's Avatar
in heat
libby heating oil burner plumbing and a/c I have a van that looks just like it , I live in buxton
Old Jan 27, 2010 | 12:07 AM
Furian's Avatar
Furian
Yeah, the integrated flames really look cool!
Old Jan 27, 2010 | 12:55 AM
TexasRebel's Avatar
TexasRebel
should just be a round 4 pin connector just inside your driver side headlight...
Old Jan 27, 2010 | 01:22 AM
thedaddycat's Avatar
thedaddycat
You could get a Bright Box that would turn on the fog lights with the high beams and just use the switch for having them on with the low beams. At least that's how they work with my '03, not sure about '08...
Old Jan 27, 2010 | 05:45 AM
in heat's Avatar
in heat
well I pulled the drivers side headlight and there is no plug any where I called the dealer and they said to bring it in and they would dig it out for me
Old Jan 27, 2010 | 06:54 AM
in heat's Avatar
in heat
my truck had a plow installed for me when I bought it and I think it got lost somewhere under the hood? its got an isolation modual that when you plug the lights in from the plow it switches the truck lights off and turns the plow lights on its a mess of wires behind the headlight
Old Jan 27, 2010 | 09:01 AM
thedaddycat
I had a Boss brand plow installed on mine and it has a switch in the cab to go from truck to plow for headlights. The Bright Box I have will still turn on the fog lights even if it's in the "Plow" position. Here's a link.....
Brite Box - TruckCustomizers.com
They also have something they call a "Bulbzilla" kit which will allow 9005/9006 or H9/H11 swaps.
Other folks make a heavy duty harness that gives you higher voltage to the bulbs for more light output. There are several options available to get better light output, which seems to be what you're after...
Old Jan 27, 2010 | 01:11 PM
TexasRebel's Avatar
TexasRebel
by "inside" I mean next to the radiator.
Mine was just outside the horn, and inside the headlight.
