Sponsored by: Real Truck
Torqshift Transmission
Old Jan 25, 2010 | 07:08 AM
ejohnson7's Avatar
ejohnson7
I have a 2006 ford 450 with the V-10 gas engine and the 5 speed torqshift transmission. I do not like the way it shifts when in the tow/haul mode. Does any one know if it is possible to get the tow-haul re-programmed to a different shift pattern either by a dealer or an aftermarket place??
Old Jan 25, 2010 | 07:23 AM
m350's Avatar
m350
What do you not like about it?
T/H mode is setup to keep the tranny in a gear longer, preventing the tranny from hunting through the gears,,,,really only seem to need it when towing Heavy trailers,,my trailer's can weigh in 5 to 8k lbs,,and I rarely use T/H mode,,,,mostly when braking,,,the braking feature works sweet on my truck!
Old Jan 25, 2010 | 07:36 AM
Cowboy65's Avatar
Cowboy65
ejohnson7, welcome to FTE.
I think if you change the shift points when in tow-haul mode it defeats the purpose which is to prevent gear hunting as m350 said above. On my truck the gear changes are not quite as smooth in tow-haul mode but I have always attributed that to the fact that the engine was at a higher RPM.
Old Jan 25, 2010 | 09:41 AM
mlminor's Avatar
mlminor
I love the way my '08 shifts in T/H...
It's scary how good the darn thing operates. I'm just afraid of en electronic glitch say, 10-12 years down the road.
Maybe there is an update that some sort of re-flash could help your '06?
Good Luck
KW7DSP
Oct 10, 2015 01:58 PM
lwems
Apr 28, 2013 12:10 PM
spud57
All Things Towing
Sep 15, 2010 07:29 PM
Mr Hanky
Sep 1, 2010 08:54 AM
aaronbrace
Jun 26, 2010 01:24 AM
