Replacing double cardan joint.....
Old Jan 24, 2010 | 05:03 PM
bmac4020's Avatar
bmac4020
Is there a way to repalce the u joints within a double cardan joint without messing up the bearings inside the ball?
Thanks
Old Mar 20, 2010 | 08:39 AM
transit's Avatar
transit
what is really in the ball? in my truck shop put a u joint in the cardan they had it part and i think parts are missing in mine u-joint burn t out again, when i took it apart thiers the ball a seal,spring and what look like two washers is this right or am i missing parts? also should you replace both u joints in the cardan at the same time and if so why?
Old Mar 20, 2010 | 06:18 PM
bmac4020's Avatar
bmac4020
There are needle bearings inside of the ball. Here is a good write up I found:
Double-Cardan Driveshaft Rebuild
MyFordExcursion
Jan 21, 2016 05:16 PM
winger4647
1978 - 1996 Big Bronco
Jan 10, 2016 08:49 AM
Ian_C
Mar 9, 2015 09:22 PM
FourXFord2
Jun 25, 2014 07:50 PM
Farmboy429
Offroad & 4x4
Jun 12, 2014 07:18 AM
