Offroad & 4x4
Driveshaft binding.
Old Jun 10, 2014 | 10:09 PM
Farmboy429's Avatar
Farmboy429
Driveshaft binding.
Hey guys,
I have a 1985 F-150 regular cab shortbox with a 7.3L in it. It has a C6 and an NP208 transfer case with a Dana 60 up front and a Sterling 10.25 out back. My front driveshaft has some binding/grinding issues at the transfer case and I'm looking for some advice on putting a CV joint or double cardan on the front driveshaft on the transfer case end. Has anyone done this and have some pointers to offer on the process and the parts and skills needed?
If i take it to a local driveline shop are they going to be able to accomplish this for me? Can I simply replace the yolk on the driveshaft with a double cardan and put a slip yolk eliminator type flange output shaft on the front output of my transfer case? I have a double cardan on the rear so I had to swap a flange style output shaft onto the rear of the transfer case to bolt the double cardan onto but I cant seem to find the same thing for the front. Any help would be greatly appreciated.
Old Jun 11, 2014 | 12:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
your best bet would be to just get a front drive shaft for a F-350. it will have the double joint in it, and it will be the proper length
Old Jun 11, 2014 | 09:47 PM
Farmboy429's Avatar
Farmboy429
Thanks for the response. Do you know what years of F350 came with the double cardan on the front? and if the yolk off of whatever transfer case they were running would work with an NP208?
Old Jun 12, 2014 | 07:18 AM
tjc transport
i ain't rite
if i remember correctly, all 85 to 97 F-350's with a dana 60 front axle came with the double joint front axle.
as for the working with a NP208, that is one you are going to have to figure out on your own. but at the most i could only see it as getting the proper ujoint to make it work.
goodB0Y
Offroad & 4x4
Nov 7, 2017 10:13 PM
crucialprospect
26
Apr 11, 2017 12:09 AM
blake 7.3L
Apr 19, 2010 02:40 PM
lastchance
Jul 16, 2004 08:45 PM
murphy
Nov 21, 2003 06:16 PM
