Will not upshift / revving on its own
My truck is a 2003 F150 Supercrew Lariat 5.4 with about 210k (km) on it. Every now and then it will not upshift and seems to be revving up on its own. Seems to be mostly when it is cold out and with moisture in the air (snow mainly). Eventually it will stop and drive normal. But when it happens if I come to a stop and put it in neutral it will rev up to about 2000 rpm on its own. When it is having this symptom it will hold 2nd or 3rd gear and rev fairly high (2500-4000) without shifting up.
I immediately thought that it would be the IAC so I replaced it with a new Ford one. I thought that it had fixed it but the problem came back the next cold wet day.
Is there something that I am missing? Where do I go with this next. It is so intermittent and usually far from home that it is hard to figure out. The engine makes good vacuum and it is steady so I did not think that it would be a vacuum leak.
Thanks in advance.
Thanks in advance.
sony420
16
06-15-2015 10:05 PM
Xcursion88
04-02-2015 10:25 PM
