I have a 2000 Expedition and today my check engie light came on. I pulled the following 3 codes, P 1000, P 1635 and P 0155. I looked up what these codes mean but am still unsure where to procede from here.
p1000 is a code that means it hasn't been run long enough to go through all the obd checks normal code you can ignore it
p0155- During testing the HO2S Heaters are checked for opens/shorts and excessive current draw. The test fails when current draw exceeds a calibrated limit and/or an open or short is detected
probabaly a bad o2 sensor
p1635-This Diagnostic Trouble Code (DTC) indicates the tire and axle information contained in Vehicle ID block (VID) does not match vehicle hardware.
