Bearing Question?
Old Jan 24, 2010 | 11:27 AM
longhorns13's Avatar
longhorns13
Bearing Question?
I replaced my passenger side hub on my ride. Read all the great threads on front ends and alot of posters helped with info. I need to replace my driver side next. Question is when I had my hub off should my axle move around when I grabbed the end of it. I greased everything and notice it moved quite a bit. Also on the tire side of the u joint I have a round gasket that is hanging on both passenger and driver side. I know this gasket has to go somewhere. It shouldn't have come from the axle housing since it cannot fit over the yokes holding the u joint.
Old Jan 24, 2010 | 11:54 AM
engineer58's Avatar
engineer58
The axles do move around, they are not quite as rigid as you would think they should be. As for your gasket that is hanging, the only seal that I can think of is the round seal that presses onto the stub axle shaft. If that seal is not intact it will allow moisture into your hub area and sieze everything eventually.
Old Jan 24, 2010 | 11:58 AM
longhorns13
This could be why my bearing are bad.
Old Jan 24, 2010 | 12:05 PM
SGnAZ's Avatar
SGnAZ
that seal hanging is the dust seal
Old Jan 24, 2010 | 12:13 PM
engineer58's Avatar
engineer58
On my truck, I had to replace the seals on both sides. The inner bearing that the stub shaft rides in and the hub lockouts both completely siezed up. Luckily, I did not have to replace the wheel bearings yet. Just be aware if you need to replace those seals, they are about $40 a piece and are very easy to destroy if you do not have an installation tool. I took my axles to the local dealer and they pressed the seals on for about $20, it's a little pricey when you watch how they do it, but it beats buying another seal.
Old Jan 24, 2010 | 09:20 PM
twags6's Avatar
twags6
Tire side of the u joint is the large seal that presses onto the axle stub.
Pumpkin side of the u joint is the dust seal. These almost always fall apart.
Old Jan 24, 2010 | 10:46 PM
Waltdog's Avatar
Waltdog
of American machinists
You can get a complete set of seals here:
www.partsguyed.com
Old Jan 25, 2010 | 10:20 PM
longhorns13
www.partsguyed.com
The pic of the seals has what I see hanging. I you look at the seal that is on the motorcraft box, the top part is what is hanging. So I guess the seal has seperated somehow. At least part is still in.
Old Aug 3, 2010 | 09:17 PM
jdross440's Avatar
jdross440
Is the inner bearing replaceable without replacing the complete hub assy?
If so, does anyone know the part number for the inner bearing?
My truck is a 2000 F250 PSD.
Old Aug 3, 2010 | 09:25 PM
engineer58's Avatar
engineer58
Yes, they can be replaced without buying the hub assembly and for a much less amount of cash. I do not know the part number, sorry. I got my mine at NAPA.
Old Aug 3, 2010 | 09:30 PM
jdross440's Avatar
jdross440
I believe I found the part number at Rock Auto: TIMKEN Part # B2110 Needle Bearing Shaft Diameter=1.3125" Housing Diameter=1.625" Width=0.625"
4WD; Front $6.45
Also: SKF Part # B2110
{#013-0599-6, 1458B2110, 363274, 3634274, 3965121, 4746127, 550759, 610446R91, 610466R91, 682-5450, 70929192-6, 8121402, C6TZ3123A, CB2110, FB2110, J8121402, SCE2110, ZZL0-26-151}
4WD; 2 required per vehicle; Front $8.59
binuya
20
Sep 30, 2009 09:39 AM
chewyjackson
54
Dec 24, 2008 09:41 AM
FrontRangeF150
Apr 3, 2007 05:20 PM
fordor
Oct 22, 2006 11:41 AM
