Sponsored by: Auxito
Single function overhead console (compass) not working?
Old Jan 23, 2010 | 11:15 PM
EZFEED's Avatar
EZFEED
Any ideas guys? I did a search and all I picked up on here was repairing the overhead console with trip,mpg computer and the transistors not being soldered in correctly.
How about the overhead console in the XL trucks? The one with just a compass (I think there was a thermometer function too?)? Mine has not worked for about a year and I havent yet thought about fixing it till now. I actually did use it quite a bit actually when on trips out of state and I'd like to fix it.
Any ideas? How to remove? Wiring schematics?
Old Jan 24, 2010 | 09:12 AM
IndySilverAnny's Avatar
IndySilverAnny
Mine was not working at all when I got it. I took it out, jiggled the connector and it came on. Compass works, (after calibrating) but thermometer reads 40deg. low. Swapped the guts with another I had from an explorer, and it still reads the same. Replaced sensor behind grill, and it still reads low. Not sure what to do now.
Old Jan 24, 2010 | 10:06 PM
EZFEED's Avatar
EZFEED
Interesting, thanks for the reply I wonder if the compass runs to the PCM somewhere....I highly doubt it. I was sure it was on its own circut.
How did you get the console off????
Old Jan 25, 2010 | 05:19 AM
IndySilverAnny
Theres' a single screw towards the front, then you just grab the edges on the sides and pull down. it snaps right off.
Old Jan 25, 2010 | 06:18 AM
torkum's Avatar
torkum
mmenzies
Feb 9, 2016 07:33 PM
NELFLOW
Oct 21, 2015 07:03 PM
8vettes
1978 - 1996 Big Bronco
24
May 1, 2014 12:25 PM
Whitey Ford
Sep 13, 2012 07:48 AM
Gutlassf250
Jun 23, 2010 01:12 AM
