Torque Modulation On/Off --what is this?
Old Jan 23, 2010 | 05:36 PM
Junebug_'s Avatar
Junebug_
What is Torque Modulation On/Off and can anyone talk about how this relates to towing heavy loads?
Thanks.
Old Jan 23, 2010 | 05:44 PM
alloro's Avatar
alloro
In a nutshell, Torque Modulation is simply varying the shift points to increase or decrease torque for the load at hand.
Old Jan 23, 2010 | 06:02 PM
Junebug_'s Avatar
Junebug_
I see. So would I want it off for towing heavy loads?
Old Jan 24, 2010 | 12:11 AM
alloro's Avatar
alloro
Nope, if you turn it off it can't do it's job.
Old Jan 24, 2010 | 10:27 AM
Junebug_'s Avatar
Junebug_
Hmm...at the risk of being pesky....why in the heck is it "turn-off-able" then? Why do these hand-held turners present that option?
Old Jan 24, 2010 | 02:20 PM
alloro's Avatar
alloro
I'm not in the designer's head so I can only speculate. I suspect it's able to be turned off in case it acts up or needs to be serviced, just like the air suspension system.
Old Jan 25, 2010 | 07:51 AM
Johnny Langton's Avatar
Johnny Langton
Torque modulation is the PCM's ability to alter the torque output of the engine,and has absolutely nothing to do with the shift points themselves.
On the pre drive-by-wire vehicles, it involved manipulation of the spark advance to decrease the torque output the engine during shifts, and on the drive-by wire vehicles it manipulates the actual throttle angle to decrease the torque output of the engine during shifts.
JL
Old Jan 25, 2010 | 05:45 PM
alloro's Avatar
alloro
Whether spark advance is varied, throttle angle is manipulated, or little hamsters start running on the serpentine belt, the result is the same; the shift point changes along with the output torque.
Old Jan 25, 2010 | 05:48 PM
Johnny Langton
No,and yes.
JL
Old Jan 25, 2010 | 07:37 PM
Junebug_'s Avatar
Junebug_
Ok...can anyone tell me how to set the torque modulation with a hand-held tuner that is good for towing?
Old Jan 25, 2010 | 07:50 PM
Johnny Langton
For the most part, torque modulation is for nothing more than the reduction of NVH (Noise, Vibration, Harshness), and is not necessary. Now, with that said, in some applications,it is necessary for the equipment to survive(typically turbodiesel applications).I'd turn it off completely for the 5.4L and 6.8L applications with no worries at all.There is a right way and wrong way to do this,and how it's accomplished is depending on what actual parameters your handheld tuner changes.
JL
Old Jan 25, 2010 | 08:01 PM
Junebug_'s Avatar
Junebug_
Thanks JL.
Old Jan 25, 2010 | 08:02 PM
Junebug_'s Avatar
Junebug_
I guess that you are telling me that this 'parameter' does not effect towing at all.
Derek86
Jul 28, 2016 07:59 AM
brianf40
Jul 6, 2016 05:31 AM
Im50fast
Nov 25, 2013 05:10 AM
DSMMH
Feb 10, 2010 11:50 AM
