Paint FAIL
Old Jan 23, 2010 | 06:16 PM
bdrummonds's Avatar
bdrummonds
Pop is correct on the zinc chromate primer. If you dont use it on metal, the paint will flake.
Use undercoating in a can from the local auto parts store. its a lot smoother than the bed liner. Sticks to dern near anything. I would probably still prime with a zinc chromate primer first.
Old Jan 23, 2010 | 06:34 PM
Smokin''s Avatar
Smokin'
Smokin
The zinc chromate isn't expensive, and I can buy it online...same with the undercoating. Its worth a try.
Those hooks on the outside of my truck, they are rope cleats. Can't find the type I have specifically, but they make some cool ones, even ones that fold flat when you aren't using them.
Old Jan 23, 2010 | 06:51 PM
frdf250's Avatar
frdf250
ehh i wouldnt use the herculiner, i did the same prep like described on my bed, i had a metal toolbox in the back and it sloshed around after i let the bed cure for about a week, tore the hole thing up like there was someone with a metal rock rake scratching it.
i would do the prep, use POR15 then bake it. just make sure the metal is pretty warm room temp mabey a little more when you paint them...just my .02
Old Jan 23, 2010 | 06:52 PM
frdf250's Avatar
frdf250
btw if ur baking them i love apple pie/peach cobbler annnnnnnddd now i will be running just like izzy...
Old Jan 23, 2010 | 07:02 PM
Smokin''s Avatar
Smokin'
Smokin
I make a mean apple pie...from scratch....once in a blue moon!
You guys are quick to antagonize me...also quick to run away from a 5'6" woman.
I wonder how well this stuff would work on the plastic lights. http://www.amazon.com/Duplicolor-Adh.../dp/B0007UAXJQ
The POR 15, isn't it a lot like the undercoating?
Old Jan 23, 2010 | 07:19 PM
Izzy351's Avatar
Izzy351
Damn right I'm quick to run. Look at your av!! I'll have to borrow Dan's screen name.
Old Jan 23, 2010 | 07:35 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
I had the same problem with some valve covers that I bought for my cobra. I kept trying all kinds of paint with no success. I finally had them sandblasted and powder coated them. They have held up for about 7or 8 years. not real cheep, I think around $200 or so
Old Jan 23, 2010 | 08:19 PM
frdf250's Avatar
frdf250
lol well i wont run if there fresh apple pie
and no, it actually looks really glossy, i had to bend a piece of sheet metal after i realized there was a hole in one of the support of my bed, i banged the H**L out of it and the paint didnt even flake. i was throughly convinced that i will be using it for everything, it leaves a reall nice gloss if you spray it on, and more like a matte flat finish if you brush it.
Old Jan 23, 2010 | 08:21 PM
frdf250's Avatar
frdf250
<a href="http://s813.photobucket.com/albums/zz59/philipberardi/?action=view&current=DSC_0005.jpg" target="_blank"><img src="http://i813.photobucket.com/albums/zz59/philipberardi/DSC_0005.jpg" border="0" alt="Photobucket"></a>
look in the center between the rails above the gas tank...that is por15 the rails are rattle can.
Old Jan 24, 2010 | 01:13 AM
canister's Avatar
canister
I also say use POR-15. I did my oil pan with it and the stuff is good. Just get one of their starter kits. It has everything you need. I was able to do about 3 coats on the oil pan with it. Just make sure you follow the directions exactly as they say. Its only about $20 + shipping. Check it out.
SUPER STARTER KIT-POR-15 Inc.
Old Jan 24, 2010 | 07:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
i will third the POR-15 Lisa.
and don't waste you money on the herculiner. it don't hold up.
we tried it on a few trucks, and within 3 months it was peeling.
and i will take a pecan pie when you start creating.
Old Jan 24, 2010 | 07:54 AM
guthrie&co's Avatar
guthrie&co
Herculiner. it sticks to everything and durable. I coated the floor with it in my 20ft enclosed trailer.
Old Jan 24, 2010 | 07:56 AM
  #28
spinella's Avatar
spinella
i think like anything else...prep work is everything.
Old Jan 24, 2010 | 08:28 AM
  #29
damicofuel's Avatar
damicofuel
Just make sure you clear the top coat on the por-15, or it will dis color.
Old Jan 24, 2010 | 09:30 AM
  #30
Smokin''s Avatar
Smokin'
Smokin
Thanks guys. its nice to have the wealth of knowledge here at my fingertips. I'll let you all know what I end up doing with these.
