Sponsored by: Real Truck
17 inch wheel psi
Old Jan 23, 2010 | 03:59 PM
ajordan193's Avatar
ajordan193
17 inch wheel psi
I have 17 inch wheels on my 06 PSD. The door sticker says they should be at 75 psi both front and rear. At that psi the truck rides like a brick unloaded. What is everyone else running their tires at?
Old Jan 23, 2010 | 04:06 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I ran 265/70R17s at full pressure with the 6k front springs, and I had no complaints.
Old Jan 23, 2010 | 04:28 PM
SDTriton250's Avatar
SDTriton250
The 17" 245/75 R17 Conti's on my 2010 F250 ride pretty rough too at 75psi. I keep thinking about airing them down some but I keep forgetting to look up at what pressure the TPM starts squeaking. I get enough of that from the other seat! It still rides better than my 3/4 ton Dodge at 40psi front and rear. Those Michelin XPS A/S with three steel belts ride hard as rocks at any pressure. That or it was the truck...
Old Jan 23, 2010 | 04:53 PM
Furian's Avatar
Furian
You Keep What You Kill
I run Michelin LTX A/T2 tires in size LT275/70R18E. I run 65 psi when not hauling/towing and the ride is acceptable for a F350.
Old Jan 23, 2010 | 07:52 PM
Ford ST's Avatar
Ford ST
I have 37inch BFG AT's. I am running 50 in front and 45 in the rear when not hauling anything. I adjusted the air by looking at the contact patch. thats on a crew cab 7.3.
Old Jan 23, 2010 | 10:43 PM
ajordan193's Avatar
ajordan193
Thanks for the info. I just aired mine down to 65 front and back. This seems to be a lot softer of a ride then the full 75.
wingedone
All Things Towing
Jun 15, 2014 07:54 PM
jdb9083
Aug 19, 2013 09:41 AM
kcchief434
Feb 23, 2009 07:26 PM
slisty
Sep 12, 2006 06:30 PM
12PSI
Oct 16, 2003 08:50 PM
