Anyone running Vintage air's compact heater?
I was looking around for a decent heater with defrost and found this one Vintage Air 506101 Compac Heater w/ Defrost
I have used their A/C heaters before but not this type. It would be for our 51 F1. Any feed back would be great.
Kevin
LFD Inc.
Kevin
LFD Inc.
Well, what heats it up, is it electric or gas fired? It states it doesn't use engine coolant.
So before you decide to install one, if it's electric, you better make sure you have at least a 100 amp alternator (no generator) to support it. Heat is watts. Heating watts are amps -lots of them.
It is by engine coolant. I guess I am missing were it said no engine coolant. Here is another supplier and it comes with the on off water valve. Chevs of the 40s: 506101 - VINTAGE AIR -COMPACT GEN-II HEATER W/ DEFROST. ELECTRONIC CONTROLS
Kevin
LFD Inc.
Kevin
LFD Inc.
Kevin
LFD Inc.
Kevin
LFD Inc.
Well I just went to the Dreamers site and it states that it has a water cutoff??? Must be a typo on one of them. If you go with this unit let us know how it works out. I will have to get something for my 53 as the cab was gutted when I bought it!
I have a older vintage air/heat unit in my 55. I do not have the air hooked up. The heat works very well, however the down side is the heat has no floor vents, only blows air out the front vents. It is a underdash unit and fairly compact and plenty of room to mount and sits nearly level with face of dash when installed. It will heat uninsulated cab in 25 degree weather with no issue. Defrost is weak but works better than the original ford unit.
Larry
Larry
Just went to your link and when I went to the summit sight it states that it does not use engine coolant to heat?????? Hummmmmmmmm
Here is the install link from V.A. http://www.vintageair.com/DownloadsS...r%20(Inet).pdf
Summit is a type-o. It took me several times reading summits info before I finally found what you were talking about But I have a good excuse, I was up from 8:30pm to 4:30am holding my 2 1/2 year olds head as he was throwing up every 20 min like clock work. But when we woke up this morning (me on the floor of his room next to his bed) he says Daddy I want lunch! Rough night.
Kevin
LFD Inc.
Kevin
LFD Inc.
Personally, I don't see what one would gain using Vintage Air's heater only unit vs. the standard box heater that was available originally. It has no difference in function, as it doesn't have fresh air or dehumidified defrost, and it surely does cost a heck of a lot more. And at 10x10x6, I don't think it's much, if any, smaller than the little standard script Ford box.
terry274
08-22-2016 12:29 PM
Conserv
01-17-2014 12:40 PM
