Power steering fluid leak.
Old Jan 22, 2010 | 04:12 PM
pick1967's Avatar
pick1967
Question Power steering fluid leak.
Anybody have an idea where to start with finding the leak and procedure for fixing when found? 06 F250 CC . Thanks for any help, Mike
Old Jan 22, 2010 | 04:41 PM
texans's Avatar
texans
can you see any wet spots where it might be coming from? try having someone work the steering wheel while you look for leaks. look under the hood, under the truck, and through the grill at the cooler for posible signs of leaks. as far as fixing it depends on where the leak is at.
Old Jan 22, 2010 | 07:12 PM
tazo's Avatar
tazo
I had a fitting that goes to the pump get loose. It was a pain to tighten since there isn't much space to turn the wrench. So maybe start with checking the fittings for tightness. The fitting that came loose for me was on the drivers side firewall.
jakegypsum
Oct 3, 2009 11:07 AM
Lookinfurfun
Sep 13, 2002 11:49 PM
pr
Mar 10, 2002 06:32 PM
fordmandan
Modular V8 (4.6L, 5.4L)
Jan 13, 2002 07:51 PM
Feb 26, 2001 07:43 AM
