CCV Mod
Old Jan 22, 2010 | 05:08 PM
big poppa's Avatar
big poppa
Originally Posted by N V US Lawn Care
I ran mine all the way back with 16 feet of heater hose, 3/4"...a 5/8" 90 degree elbow, 3 clamps, and yes, i got a package of various sized rubber caps from Advance Auto...the biggest expense was the heater hose...i think it cost $24 all together...pics to come soon...
Be careful with the running of the hose al the way back, like mention earlier, condinsation can build up in the hose and if it freezes, you'll have the problems mentioned above, crankcase presure, bad. Does it freeze down in AL.?? TD, I just ran mine over the booster like Keith's, right to the ground, a drip here and there, no biggie. I will evenually do a trap, Clay's system is nice.
Old Jan 22, 2010 | 05:48 PM
N V US Lawn Care's Avatar
N V US Lawn Care
Originally Posted by tdpower
Maybe I'll just vent it out toward the fender wheel well. What kind of hose did you guys use? I guess you can get the caps for the air duct hole at an auto parts store?
Here's mine...
It runs all the way back beside the spare...
Old Jan 22, 2010 | 05:59 PM
tdpower's Avatar
tdpower
That looks good David! Thanks for the pics. I guess you put a 90 degree coming off the valve cover?
Old Jan 22, 2010 | 06:03 PM
N V US Lawn Care
Yep...second pic shows it...thanks...i waited awhile before i did it...
Old Jan 22, 2010 | 06:24 PM
big poppa's Avatar
big poppa
David, does it get down to freezing down there?? Looks good though..
Old Jan 22, 2010 | 06:41 PM
N V US Lawn Care
Yeah, it does...i'll cross that bridge if i have to, but, so far, so good...i thought about if it froze up, i could cut the heater hose to a shorter length and terminate it just below the engine bay...the warmth of the engine compartment would keep anything from freezing...what do you think??
Old Jan 23, 2010 | 02:03 PM
PaysonPSD's Avatar
PaysonPSD
A couple times a year I put an electrician's snake through my ccv hose and pull a rag back through it. It doesn't seem to get that oily. Of course the more blow-by the scuzzier it will get.
Old Jan 23, 2010 | 02:34 PM
big poppa's Avatar
big poppa
Don't get me wrong, It looks profesionally done I just heard horror stories where condinsation built up in a valley of sorts in the hose and frozen, I think Ken powerstroker99, I think his screen name was, had something going on around his turbo exhaust side from the backpressure.
Old Jan 23, 2010 | 11:41 PM
N V US Lawn Care
Now, that sounds like a good idear thar...
Don't get me wrong, It looks profesionally done I just heard horror stories where condinsation built up in a valley of sorts in the hose and frozen, I think Ken powerstroker69, I think his screen name was, had something going on around his turbo exhaust side from the backpressure.
Thanks...i remembered today what the plug thing for the factory CCV inlet was called....i bought a package of rubber bypass fittings for $1.29...i only used one that i could slip over that fitting...i didn't need a clamp there...i read all those horror stories too, and its why i wwaited so long to do it...i'll try Joe's trick there, and if it does condensate and freeze, i'll try cutting it to terminate at the bottom of the engine compartment...
Old Jan 23, 2010 | 11:52 PM
Ponyboychris's Avatar
Ponyboychris
Here's my CCV mod with the filter trap that I made.
CCV Filter trap
Old Jan 24, 2010 | 08:39 AM
dieselboy3278's Avatar
dieselboy3278
big popa is right
i live in wisconsin and mine froze
took out the seal in the turbo
oil running out the tail pipe
so i just run it straight down now
Old Jan 24, 2010 | 10:12 AM
PwerStroke99's Avatar
PwerStroke99
Yup that was me! Thank god it didnt take out the seal in my turbo. So far so good now. Ever since i rerouted it over my Master Cylinder and evened out the hose, havent had a problem.
Old Jan 24, 2010 | 10:40 AM
  #28
N V US Lawn Care
Originally Posted by dieselboy3278
big popa is right
I went out and looked over my work, and this is what i found...i tried to maintain at least an evenness throughout, hoping for a continuous downward slope to my hose, but, i realized that i made a critical error at the rear end...i didn't really pay attention to the fact that, no matter what, it took an upward turn with the chassis...so, to repair it, i'm going to shorten the hose to terminate just before the chassis turns up, so, it will terminate right at the rear end...i want to make sure there will not be any oily residue blowing on my tires causing wheel spin, so i will snug the hose up against the chassis....
Old Jan 25, 2010 | 06:04 PM
  #29
tdpower's Avatar
tdpower
CCV done
I finished up this mod today. There was a little more smoke coming out than I expected. Anybody had a problem with a smoke test with this mod? I guess you could bypass it for an inspection. We don't have annual inspections here but may be an issue if we move.
Old Jan 25, 2010 | 06:25 PM
  #30
superduty4x4's Avatar
superduty4x4
I've had my CCV mod almost as long as I've had the truck. My hose runs up over the master cylinder, then down toward the transfer case, pokes out and runs uphill along the frame to just in front of the rear tire. Never had an issue 1 in 2 years with it freezing over or plugging up. Everyone says not to have any dips or uphill runs in the hose... well so far so good for me. The only reason mine is this way is because it was really the only way I could see to run it back any amount of length... I have a mondo fuel tank that hogs up a lot of space I could have run the CCV hose.
