Cheap way to get 2in of lift?
I only want to clear 33's so I believe 1.5'' or 2'' should be plenty (probably could keep it stock height and trim the bumper but the back is sagging a little) Would a 2'' block in the back and some new coils up front do the trick? Would I have to get new shocks for the change in ride height?
"Cheap" and "lift" do not belong in the same sentence. If you want to lift your truck, do it the right way. The right way is never the cheap or easy way. Putting a cheap lift on your truck will shorten the life of your suspension parts and put yourself at a higher risk of injury or death.
Sorry to sound so much like a warning label but people just don't seem to get this.
If you put a leveling kit on the front it will raise it about 1.5" but you will need new camber bushings and if you don't do it yourself it can be tricky to find a shop that knows what they're doing.
Andym.. I wasnt being an ***. But that was quite a picture you painted from shortening component life to DEATH!! Thank you for the info though. I think buying new leafs would serve the dual purpose of giving me a little lift and improving ride quality. Same up front.
This forum is awesome and I have learned a lot so far. Im sure I will have another question later today. Trying to get a total parts list to restore the truck so im starting with the drivetrain and suspension.
I'd think that if you are sure that 2" is where ya are going to want it from here on out (I did that, then wanted 4" then 6") I'd just get some new springs and blocks for the rear and have it realigned. It will be worth it and save you in the long run from jerry-riggin something up. Whatever you do, don't get a body lift IMO.
AH HAHAHAHAHAHA and this is coming from someone who has done his fair share of stupid things, but come on,really!!! even i would never go that far as to rig up my stuff that bad, lift block... eh.. okay , but that, lol, plus new u bolts are like what, about 15 dollars at a parts store lol
