Cheap way to get 2in of lift?
Old 01-22-2010, 01:00 PM
Six5's Avatar
Six5
Six5 is offline
I only want to clear 33's so I believe 1.5'' or 2'' should be plenty (probably could keep it stock height and trim the bumper but the back is sagging a little) Would a 2'' block in the back and some new coils up front do the trick? Would I have to get new shocks for the change in ride height?
Old 01-22-2010, 01:09 PM
darthice's Avatar
darthice
darthice is offline
if you put coils on the front and alter the ride height that way it will throw your front end allignment out of whack and you will need to get it alligned what i would do is get a leveling kit and the back can fit 33s easy
Old 01-22-2010, 01:18 PM
Six5's Avatar
Six5
Six5 is offline
Good deal. If the back wasnt sagging I wouldnt even bother but do it right the first time ya know.
Old 01-22-2010, 01:19 PM
darthice's Avatar
darthice
darthice is offline
sounds like you need new leafs in the back or to take them to a spring shop to have them redone.
Old 01-22-2010, 01:25 PM
andym's Avatar
andym
andym is offline
"Cheap" and "lift" do not belong in the same sentence. If you want to lift your truck, do it the right way. The right way is never the cheap or easy way. Putting a cheap lift on your truck will shorten the life of your suspension parts and put yourself at a higher risk of injury or death.
Sorry to sound so much like a warning label but people just don't seem to get this.
If you put a leveling kit on the front it will raise it about 1.5" but you will need new camber bushings and if you don't do it yourself it can be tricky to find a shop that knows what they're doing.
Old 01-22-2010, 01:48 PM
Six5's Avatar
Six5
Six5 is offline
What a downer. I didnt mean cheap as in parts from china. I meant a cheap way to get 2'' without getting boned by the major manufacturers of lift kits. I think Im just going to buy new leaf packs for the back and new stock springs for the front. It will give me what Im looking for without crushing my wallet. I like the max tire minimum lift look personally.
Old 01-22-2010, 01:54 PM
Six5's Avatar
Six5
Six5 is offline
Andym.. I wasnt being an ***. But that was quite a picture you painted from shortening component life to DEATH!! Thank you for the info though. I think buying new leafs would serve the dual purpose of giving me a little lift and improving ride quality. Same up front.
This forum is awesome and I have learned a lot so far. Im sure I will have another question later today. Trying to get a total parts list to restore the truck so im starting with the drivetrain and suspension.
Old 01-22-2010, 02:54 PM
salmonslayer204's Avatar
salmonslayer204
salmonslayer204 is offline
I'd think that if you are sure that 2" is where ya are going to want it from here on out (I did that, then wanted 4" then 6") I'd just get some new springs and blocks for the rear and have it realigned. It will be worth it and save you in the long run from jerry-riggin something up. Whatever you do, don't get a body lift IMO.
Old 01-22-2010, 02:57 PM
andym's Avatar
andym
andym is offline
This is what some people do when they are trying to save money on a lift kit:
Now you know why I said what I did and why I said it that way.
Old 01-22-2010, 02:59 PM
salmonslayer204
WOW!! That is bad! Even my most redneck friends haven't gone this far!
Old 01-22-2010, 03:04 PM
pete17c's Avatar
pete17c
pete17c is offline
that gives a whole new meaning to "put a brick in it" ..
and ya gotta love the u-bolt 'extensions' (and I thought I couldn't weld)
Old 01-22-2010, 03:19 PM
wickedklown83's Avatar
wickedklown83
wickedklown83 is offline
AH HAHAHAHAHAHA and this is coming from someone who has done his fair share of stupid things, but come on,really!!! even i would never go that far as to rig up my stuff that bad, lift block... eh.. okay , but that, lol, plus new u bolts are like what, about 15 dollars at a parts store lol
Old 01-22-2010, 03:43 PM
Six5's Avatar
Six5
Six5 is offline
WOW!! Okie Dokie Andym. I follow
Old 01-22-2010, 09:03 PM
Paco_Jones's Avatar
Paco_Jones
Paco_Jones is offline
I'd like to see the rest of that truck
Old 01-22-2010, 09:27 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
haha i second that..... but it lookes like it held up long enough to rust
Quick Reply: Cheap way to get 2in of lift?
